Getting Started with M2P
Read more: Banana Pi BPI-M2+
BPI-M2+ H3
  • Quad-core 1.2GHz Cortex-A7 H3
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
Build your own image on M2P
GPIO
  • Execute "bluetoothctl"
  • If you don't know how to use bluetoothctl, type help, you will see more commands
  • Execute these commands:
[[Image:M2P_BT_bluetoothctl.png] [[Image:M2P_BT.png]
WiFi and Ap mode on M2P
AP mode
We use HDF5640 camara.
  • test_ov5640_image_mode.sh
  • cameratest.sh
IR function
  • Execute getevent
  • Use your IR device to send information to M2P
WringPi
  • Execute bpi_test_52pi
  • 0.96 Inch OLED Display
  • 8x8 RGB LED Martix
Reference Link
http://forum.banana-pi.org/
