BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | SPI SPEED | 40NHz | |
| 2 | SPI MODE | DIO | |
| 3 | FLASH SIZE | 32Mbit | |
| 4 | COM | COMx(Fill in the port number assigned by the computer) | |
| 5 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
