Getting Started with BPI-R4
   G=GND;  RX=BPI-R4 input;  TX=BPI-R4 output
  * Examples:
 Release Image:  https://wiki.banana-pi.org/Banana_Pi_BPI-R4#Release_image
 Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
How to burn image to SD card
   * apt-get install pv
   Click on "Flash from file" to select image.
   Click on "Select target" to select USB device.
   Click on "Flash!" Start burning.
 * Note: boot device select:  https://wiki.banana-pi.org/Getting_Started_with_BPI-R4#Prepare_to_develop
    * mtd erase /dev/mtd0
 4. Execute :
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
eth2 Link encap:Ethernet HWaddr 22:02:CE:9C:92:BA
         Interrupt:124
lo Link encap:Local Loopback
ra0 Link encap:Ethernet HWaddr 00:0C:43:26:60:88
ra1 Link encap:Ethernet HWaddr 02:0C:43:36:60:88
rai0 Link encap:Ethernet HWaddr 00:0C:43:2B:B1:F8
rax0 Link encap:Ethernet HWaddr 0C:0C:43:26:60:D8
bridge name bridge id STP enabled interfaces br-wan 7fff.eea15781ca19 no lan0, eth2
bridge name bridge id STP enabled interfaces br-lan 7fff.eea15781ca19 no apclii0 apclix0 apcli0 ra1 rai0 rax0 lan2 eth1 ra0 lan3 lan1
root@OpenWrt:/#
Accessories
1. 10G SFP Module
10G SFP+ Copper Module
root@R4CN:/# [   67.870063] sfp sfp@0: SM: enter empty:up:down event insert
[   67.875642] sfp sfp@0: SM: exit probe:up:down
[   68.199179] sfp sfp@0: SM: enter probe:up:down event timeout
[   68.215970] sfp sfp@0: module OEM              SFP-10G-T        rev 10   sn 2309250003       dc 230925
[   68.225443] sfp sfp@0: module OEM              SFP-10G-T        rev 10   has been found in the quirk list
[   68.235004] sfp sfp@0: sfp: support mode 00,00000800,00007040
[   68.240749] sfp sfp@0: tx disable 1 -> 0
[   68.244681] sfp sfp@0: SM: exit present:up:wait
[   68.343638] sfp sfp@0: SM: enter present:up:wait event los_high
[   68.349549] sfp sfp@0: SM: exit present:up:wait
[   82.476711] sfp sfp@0: SM: enter present:up:wait event los_low
[   82.482550] sfp sfp@0: SM: exit present:up:wait
[   83.584504] alloc new entry for 18:f2:2c:6f:45:3e, interface:eth2
[   83.590595] recv intf mac ae:19:d1:7e:2a:74
[   95.271188] sfp sfp@0: SM: enter present:up:wait event timeout
[   95.277715] sfp sfp@0: probing phy device through the [MDIO_I2C_ROLLBALL] protocol
[   95.821247] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.826999] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.832741] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.838479] sfp sfp@0: CL45 PHY device [0x31c3:0x1c13] found!
[   95.844217] sfp sfp@0: CL45 PHY driver [Aquantia AQR113C] found!
[   95.850215] sfp sfp@0: phy: support mode 00,00018000,000e706c
[   95.855960] mtk_soc_eth 15100000.ethernet eth2: requesting link mode inband/10gbase-kr with support 00,00018000,000a7068
[   96.273193] mtk_soc_eth 15100000.ethernet eth2: PHY [i2c:sfp@0:11] driver [Aquantia AQR113C]
[   96.357199] sfp sfp@0: SM: exit present:up:link_up
[   96.357206] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[   96.630718] sfp sfp@0: SM: enter present:up:link_up event los_high
[   96.636904] sfp sfp@0: SM: exit present:up:wait_los
[  101.395228] sfp sfp@0: SM: enter present:up:wait_los event los_low
[  101.401416] sfp sfp@0: SM: exit present:up:link_up
[  101.401426] mtk_soc_eth 15100000.ethernet eth2: resolve link status: system iface=1, line iface=0
[  101.696172] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control off
[  101.704534] br-wan: port 2(eth2) entered blocking state
[  101.709754] br-wan: port 2(eth2) entered forwarding state
 root@R4CN:/#
root@R4CN:/# i2cdetect -y 3
    0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
root@R4CN:/#
root@R4CN:/# ethtool eth2
Settings for eth2:
       Supported ports: [ ]
       Supported link modes:   100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Advertised link modes:  100baseT/Full
                               1000baseT/Full
                               10000baseT/Full
                               1000baseKX/Full
                               10000baseKR/Full
                               2500baseT/Full
                               5000baseT/Full
       Link partner advertised link modes:  10baseT/Full
                                            100baseT/Full
                                            1000baseT/Full
                                            10000baseT/Full
                                            2500baseT/Full
                                            5000baseT/Full
       Speed: 10000Mb/s
       Duplex: Full
       Port: MII
       PHYAD: 17
       Transceiver: external
       Auto-negotiation: on
       Link detected: yes
root@R4CN:/#
Note:
root@R4CN:/# [  201.763041] mapfilter:drop IP addr timeout! stop dropping IP addr.
[  499.938345] sfp sfp@0: SM: enter present:up:link_up event los_high
[  499.950712] mtk_soc_eth 15100000.ethernet eth2: Link is Down
[  499.956370] sfp sfp@0: SM: exit present:up:wait_los
[  499.961367] br-wan: port 2(eth2) entered disabled state
[  502.867442] sfp sfp@0: SM: enter present:up:wait_los event remove
[  502.873705] sfp sfp@0: module removed
[  502.877937] sfp sfp@0: tx disable 0 -> 1
[  502.881872] sfp sfp@0: SM: exit empty:up:down
[  503.164077] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000180
[  503.172853] Mem abort info:
[  503.175634]   ESR = 0x96000006
[  503.178683]   EC = 0x25: DABT (current EL), IL = 32 bits
[  503.183985]   SET = 0, FnV = 0
[  503.187030]   EA = 0, S1PTW = 0
[  503.190162] Data abort info:
[  503.193035]   ISV = 0, ISS = 0x00000006
[  503.196861]   CM = 0, WnR = 0
[  503.199816] user pgtable: 4k pages, 39-bit VAs, pgdp=000000012fd21000
[  503.206246] [0000000000000180] pgd=0000000132bfb003, pud=0000000132bfb003, pmd=0000000000000000
[  503.214936] Internal error: Oops: 96000006 [#1] SMP
[  503.219799] Modules linked in: ksmbd mt7991(P) mt7990(P) iptable_nat ipt_REJECT xt_time xt_tcpudp xt_state xt_socket xt_recent xt_policy xt_nat xt_multiport xt_mark xt_mac xt_limit xt_iprange xt_helper xt_esp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_FLOWOFFLOAD xt_CT usblp ts_fsm ts_bm spidev rfcomm pptp ppp_mppe nf_tproxy_ipv6 nf_tproxy_ipv4 nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_amanda nf_nat nf_log_ipv4 nf_flow_table_hw nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount mtqos mtfwd mapfilter libcrc32c l2tp_ppp iptable_raw iptable_mangle iptable_filter ipt_ah ip_tables hidp btusb btintel bnep asn1_decoder mt7990_dbg(P) mtk_wed(P) mtk_pci(P) connac_if(P) mtk_hwifi(P)
[  503.219869]  mt_wifi(P) hid mt_wifi_cmn evdev input_core cfg80211 compat xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 nfsd ip6_gre ip_gre gre l2tp_netlink l2tp_core udp_tunnel ip6_udp_tunnel ipcomp6 xfrm6_tunnel esp6 ah6 ip6_tunnel tunnel6 ip_tunnel rpcsec_gss_krb5 auth_rpcgss oid_registry af_key lockd sunrpc grace autofs4 dm_mirror dm_region_hash dm_log dm_crypt nls_utf8 nls_iso8859_1 nls_cp437 macsec seqiv md4 ghash_generic gf128mul gcm cts ctr ccm arc4 mtk_warp mtkhnat leds_gpio xhci_plat_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl ehci_hcd gpio_button_hotplug
[  503.390068] CPU: 2 PID: 7304 Comm: aqr107_mib_thre Tainted: P                  5.4.246 #0
[  503.398227] Hardware name: Bananapi BPI-R4 (DT)
[  503.402746] pstate: 80000005 (Nzcv daif -PAN -UAO)
[  503.407531] pc : __phy_read_mmd+0x20/0xa0
[  503.411529] lr : phy_read_mmd+0x38/0x60
[  503.415351] sp : ffffffc01388bd90
[  503.418653] x29: ffffffc01388bd90 x28: 0000000000000000
[  503.423952] x27: ffffff80f2ae3638 x26: ffffffc010a373c0
[  503.429250] x25: ffffffc010557918 x24: ffffff80f4ce8800
[  503.434547] x23: ffffffc010d83908 x22: ffffffc01388be3c
[  503.439845] x21: 000000000000e811 x20: 0000000000000003
[  503.445142] x19: ffffff80f4ce8800 x18: ffffffc010c0a1a8
[  503.450440] x17: 000000000000003c x16: 000000000000003c
[  503.455738] x15: 0000000000000018 x14: 00000000fffbd1b0
[  503.461035] x13: 00000000000001f4 x12: ffffffc010c0a160
[  503.466332] x11: 000000000000c503 x10: 0000000000000830
[  503.471630] x9 : ffffffc01388bd10 x8 : ffffff80efda0890
[  503.476927] x7 : ffffffc0eec26000 x6 : ffffffc0eec26000
[  503.482224] x5 : 0000000000000000 x4 : 0000000000000000
[  503.487522] x3 : ffffff80f4ce8800 x2 : 000000000000e811
[  503.492819] x1 : 0000000000000003 x0 : ffffff80f4ce8800
[  503.498117] Call trace:
[  503.500553]  __phy_read_mmd+0x20/0xa0
[  503.504202]  phy_read_mmd+0x38/0x60
[  503.507680]  aqr107_mib_read_word+0x2c/0x60
[  503.511850]  aqr107_mib_read+0x24/0x200
[  503.515673]  aqr107_mib_thread+0x20/0x50
[  503.519585]  kthread+0x120/0x128
[  503.522801]  ret_from_fork+0x10/0x1c
[  503.526368] Code: a9be7bfd aa0003e3 910003fd f9418005 (f940c0a5)
[  503.532447] ---[ end trace 3fa317a53584315f ]---
[  503.538554] Kernel panic - not syncing: Fatal exception
[  503.543768] SMP: stopping secondary CPUs
[  503.547680] Kernel Offset: disabled
[  503.551155] CPU features: 0x10002,20002008
[  503.555238] Memory Limit: none
[  503.559792] Starting Memory dump SMCC
[  503.563452] Memory dump SMCC failed
[  503.566929] Rebooting in 3 seconds..
10G SFP+ Fibre Module
2. 4G/5G Module
  • BPI-R4 supports M.2 USB Interface Quectel 4G LTE EM25, RM500U-CN & RM520N-GL 5G Modules.
  • If you want to use Cellular Module on BPI-R4:
   1. Install 4G/5G Cellular Module into CN16 Slot(M.2 KEYB)
   2. Inset NANOSIM Card into SIMSlot(SIM1) with card tray(pay attention to the direction)
   3. Install antenna on the module
   4. After powering on, it will automatically dial
3. NVMe SSD
  • please insert one M2.KeyM SSD into M2.KeyM slot.
4. Asia mPCIe WiFi6/WiFi6E
