Banana Pi router Comparison
Revision as of 02:26, 15 May 2018 by Sinovoip (talk | contribs)
Banana Pi Smart Router /Nas Comparison
Module BPI-R1 BPI-R2 BPI-W2
Banana Pi BPI-R1
Banana Pi BPI-R2
CPU Allwinner A20,32 Bit Cortex™-A7 2-Core 1G MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz Realtek RTD1296 64 Bit quad-core ARM A53
GPU ARM® Mali400MP2 ARM® Mali450 MP4 Mali T820 MP3 GPU
SDRAM 1GB DDR3 (shared with GPU) 432Mhz 2GB DDR3 (shared with GPU) 1600Mhz 2GB DDR4 \(shared with GPU\)
Storage "SD Card up to 64GB (SDXC) 1 SATA up to 2TB " "MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB " "MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB "
Network 4x Gigabit LAN 1x Gigabit WAN 4x Gigabit LAN 1x Gigabit WAN (MT7530) 1x Gigabit LAN 1x Gigabit WAN
WIFI 802.11b/g/n (RTL8192CU) "802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)" N/A
Vidio In CSI input for video cameras NA HDMI in
Video Out HDMI/LVDS/RGB HDMI/MIPI HDMI/ MIPI DP
Audio Output 3.5 mm Jack and HDMI out HDMI out & I2S HDMI out, I2S audio,Audio micro out
Audio In Microphone N/A 2 MIC in and HDMI in
USB 2.0 2 USB 2.0 ports, 1 OTG microUSB port 1 USB 2.0 OTG 2x USB 2.0 OTG :1 with standard USB port , 1 define with PIN
USB 3.0 N/A 2xUSB 3.0 1xUSB 3.0
HDMI in N/A N/A 1 HDMI in
TYPE C N/A N/A 1x TYPE C
Mini DP N/A N/A 1x Mini DP
PCIE N/A 1* mini PCIE,1*pcie with 14 PIN define 1xM.2 KEY B : USB 2.0 for 4G with Micro SIM card slot ;2xM.2 KEY E:1 with PCIE 2.0/USB 2.0,1 with 1 pcie 1.1/SDIO/USB 2.0 interface
GPIO 40-PIN GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
Power Source 5 volt via MicroUSB and/or MicroUSB (OTG) 12 volt via DC In  12 volt via DC In
Buttons Reset button Power button, Uboot button Reset button Power button, Uboot button Reset button Power button, Uboot button
LED Power key and RJ45 Power key and RJ45 Power key and RJ45
Remote IR reciever IR reciever IR reciever
Board Size 120mm ×100mm 120mm ×100mm 120mm ×100mm
Weight 60g 60g 60g
OS Android and Linux OS OpenWRT Android and Linux OS OpenWRT Android and Linux OS OpenWRT
