Banana Pi BPI-Wifi6 Router
BPI-Wifi6 Router Introduction
- Dual core ARM cortec A9 1.2G Hz
- Integrated 5GE PHY, one RGMII
- Supports 6 GE MACs,1000M/100M/10M rate mode and standard MIB statistics
- Supports IEEE802.11a/b/g/n/ac/ax wireless LAN communication protocol
- Support Wifi AP mode and STA mode
- Support WPA,WPA2, WPA3 encryption and decryption, support China WAPI standard
- PoE function support
Banana Pi BPI-Wifi6 Router specifications
BPI-Wifi6 Router Debug UART(J3)-TTL3.3V | |||
Debug | UART(J3)-TTL3.3V | ||
PIN1 | RXD | ||
PIN2 | NC | ||
PIN3 | 3.3V | ||
PIN4 | GND | ||
PIN5 | TXD |
PoE support
Easy to add PoE function suppport on BPI-Wifi6 router,The PoE module port is reserved on the board. If the PoE module is welded to the board, the PoE network cable power supply function is supported
- Note : use BPI-RT5400-12V PoE module.
appearance design
we have design a case for BPI-Wifi6 Router board ,so you can use this board directly as a standard wifi6 router
this board support customized service. You can quickly produce your own wifi6 router products. And develop your own software on it
- Please refer to github bsp's pdf document: 创耀_TGP3.0开发手册_2023.4.20.pdf ----- gtihub website: https://github.com/BPI-SINOVOIP/THG6500-TAX2-OPENWRT-BSP
- Source code on github: https://github.com/BPI-SINOVOIP/THG6500-TAX2-OPENWRT-BSP
- Banana Pi BPI wfi6 router with Triductor TR6560 + TR5220 wifi SOC test PoE and OpenWRT:https://www.youtube.com/watch?v=Nf03ssN8ez0
- OpenWRT image with github code:
- Baidu Cloud: https://pan.baidu.com/s/1uZ6Y4DSXhoPs83OE38bV6Q?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/file/d/1E5ArjrTuQAThgxh1xCD7LyqxHqh1eArV/view?usp=sharing
- Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-wifi6-router-openwrt-image/16144
- BPI Aliexpress shop : https://www.aliexpress.com/store/group/BPI-Wifi-6/1101951077_40000004162529.html?spm=a2g0o.store_pc_saleItems.0.0.77487862alHitN
- SinoVoip Aliexpress shop : https://www.aliexpress.com/store/group/BPI-WIfi-6/1100417230_40000004365851.html?spm=a2g0o.store_pc_saleItems.0.0.1b4430d9kDRD79
- Taobao shop : https://item.taobao.com/item.htm?spm=a2126o.success.0.0.729a4831qQlwiq&id=725082757481&qq-pf-to=pcqq.group
