Getting Started with BPI-R4
* Using your USB-Serial cable Connect to debug console on BPI-R4
* Examples:
Accessories
1. 10G SFP Module
The SFP serdes of BPI-R4 requesting link mode inband/10gbase-kr, so only SFP that support this protocol can be used!
10G SFP+ Copper Module
Note:
