Getting Started with BPI-R4
Revision as of 23:58, 19 October 2023 by Sinovoip (talk | contribs) (10G SFP+ Copper Module)
 * Using your USB-Serial cable Connect to debug console on BPI-R4
  * Examples:
Accessories
1. 10G SFP Module
The SFP serdes of BPI-R4 requesting link mode inband/10gbase-kr, so only SFP that support this protocol can be used!
Note:
The temperature of this module is very high when used for a long time, and can reach 90°C. Be careful to prevent burns.
10G SFP+ Fibre Module
2. 4G/5G Module
3. SSD
4. Asia mPCIe WiFi6/WiFi6E
