Banana Pi Smart router Comparison
Module |
BPI-R1 |
BPI-R2 |
BPI-W2
Photo |
CPU |
Allwinner A20,32 Bit Cortex™-A7 2-Core 1G |
MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz |
Realtek RTD1296 quad-core ARM A53
GPU |
ARM® Mali400MP2 |
ARM® Mali450 MP4 |
Mali T820 MP3 GPU
SDRAM |
1GB DDR3 (shared with GPU) 432Mhz |
2GB DDR3 (shared with GPU) 1600Mhz |
2GB DDR4 \(shared with GPU\)
Storage |
"SD Card up to 64GB (SDXC) 1 SATA up to 2TB " |
"MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB " |
Network |
4x Gigabit LAN 1x Gigabit WAN |
4x Gigabit LAN 1x Gigabit WAN (MT7530) |
1x Gigabit LAN 1x Gigabit WAN
RF |
802.11b/g/n (RTL8192CU) |
"802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)" |
**Option** ,not support onboard WIFI & BT
Vidio In |
CSI input for video cameras |
NA
Video Out |
HDMI/LVDS/RGB |
HDMI/MIPI
Audio Output |
3.5 mm Jack and HDMI |
N/A
Audio In |
Microphone |
N/A
GPIO 40-PIN |
GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. |
Power Source |
5 volt via MicroUSB and/or MicroUSB (OTG) |
12 volt via DC In |
USB Ports |
2 USB 2.0 ports, 1 OTG microUSB port |
2 USB 3.0 host,1 USB 2.0 OTG |
Buttons |
Reset button Power button, Uboot button |
LED |
Power key and RJ45 |
Remote |
IR reciever |
Board Size |
120 mm × 100mm |
Box Size |
28 mm x 170mm x 150mm |
Weight |
60g |
OS |
Android and Linux OS |
