香蕉派 BPI-M6
About VideoSmart VS680
- Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
- Imagination GE9920 GPU
- NPU for AI up to 6 .75Tops
- 4GB LPDDR4
- 16GB eMMC flash
- M.2 Key E(PCIe + MIPI CSI)
- 4 USB 3.0
- 1 GbE ethernet
- 1 HDMIin and 1 HDMIout
HardWare Specification of Banana pi BPI-M6 | |||
CPU | Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor | ||
GPU | Imagination GE9920 GPU | ||
NPU for AI | Up to 6 .75Tops | ||
Memory | 4 GB LPDDR4 | ||
Video | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port | ||
Display | MIPI DSI interface | ||
M.2 interface | M.2 Key E(PCIe + MIPI CSI) | ||
Switches | SPI boot and U-boot | ||
Power Source | 5 volt @3A TYPE C | ||
OS | Android and Linux |
Source code on github
documents
- Senary VS680(Synaptics SN3680) datasheet:
- The VS680 NPU is ranked first on AI benchmark website: https://ai-benchmark.com/ranking_IoT.html
- BPI-M6 AI function test: https://www.youtube.com/watch?v=RIO0K_V12D4
