Getting Started with BPI-R3 MINI
Revision as of 02:00, 20 September 2023 by Sinovoip (talk | contribs) (iperf3 test)
MediaTek MT7986(Filogic 830)
  • MediaTek MT7986A(Filogic 830) Quad core ARM Cortex A53
  • Wifi 6 2.4G/5G(MT7976C)
  • 2G DDR RAM
  • 8G eMMC flash
  • 128MB Nand flash
  • 2x 2.5GbE Ethernet port
  • 1x M.2 Key B USB inerface
  • 1x M.2 KEY M PCIe inerface
  • 1x USB2.0 interface
 * Prepare USB-Serial interface
 * Using your USB-Serial Connect debug console on BPI-R3 MINI
  Note: Debug Uart 3.3v TTL
 *R3mini boot switch Jumper Setting
  Note: EMMC Boot or Nand boot Support.
Warnning
 Note: Because BPI-R3 MINI can't support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device.
 Anytime please confirm that one EMMC or Nand device include one bootable image, it's very important!!
 if you want to update EMMC device, please boot from Nand
 otherwise you update Nand device when it boot from EMMC.
 Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc-r3mini.img) for example, the steps are below:
 1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
 2. Change boot switch Jumper, the board boot from Nand device, then power up the board.
 4. Execute following command to enable and copy image to EMMC device:
    * dd if=bl2_emmc-r3mini.img of=/dev/mmcblk0boot0
    * dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
 5. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device.
 1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk.
 2. Change boot switch Jumper, the board boot from EMMC device, then power up the board.
    * mtd erase /dev/mtd0
    * dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
 5. power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device.
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
lo Link encap:Local Loopback
         Interrupt:6
root@OpenWrt:/#
iperf3 test
2.5G Ethernet:
R3miniA(WAN)---|            |
               |2.5G wwitch |---Ethernet             R3miniA <-------iperf3------> R3miniB
R3miniB(WAN)---|            |
                    R3miniA(WAN)---|            |
                                   |2.5G wwitch |---Ethernet             R3miniC <-------iperf3------> R3miniA
R3miniC(WAN)---(LAN)R3miniB(WAN)---|            |
5GWi-Fi:
iPhone 5Gwifi <-------iperf3------> (Wi-Fi) BPI-R3mini
Note: The distance between iPhone and R3mini is about one meter.
  • echo 433(22+411) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio433/direction
  • echo 1 > /sys/class/gpio/gpio433/value
FAN
  • CN16 is a 1.25 pitch 3PIN socket, used to connect the fan, supports PWM control.
PWM FAN Control
  • echo 0 > /sys/class/pwm/pwmchip0/export
  • echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
  • echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
  • echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
  • echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
M.2 KEY B slot
currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN
when you install one 4G/5G module, you may check it.
4G/5G Module
BPI-R3mini supports M.2 KEYB USB interface Cellular network module: 4G LTE EM05, 5G Quectel RM500U-CN/RG200U-CN and RM520N-GL/RM500Q-GL Series.
The released image(2023-09-12 or later) default driver is RM500U-CN and RM520N-GL, Install one of these two modules and you can use it directly.
If use EM05 or others,you will most likely need to modify the driver.
Wi-Fi Ap mode on BPI-R3mini
  • ra0 is MT7986a 2.4G wifi
  • rax0 is MT7986a 5G wifi
Serial cable
Because the UART0_TXD of the debug port is also a wifi strap pin, this pin needs to be pull-low when poweron,
some serial cable have strong pull-up, such as PL2303,if it is inserted before powering on, it will cause the wifi chip to be recognized incorrectly, and the wifi function will fail.
Other types including cp2102,ch340 and FDTI are all available, serial cable power domian must be 3.3v TTL standard.
You can buy the serial cable here: https://www.aliexpress.us/item/3256805457599756.html?
If your computer has a USB TypeC connector and supports PD12V/1.5A (20W) or above, you can also directly use the computer to power BPI-R3mini.
Moreover, since BPI-R3mini has built-in USB to serial port chip CH340E, you do not need to use additional serial cables.
NOTE:If your computer does not support USB PD, then the R3mini will most likely keep restarting.
Because the power consumption of R3mini is relatively large (all peripherals are plugged in and the power consumption is close to 20W when running)
  • MT7986a Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
TTL Voltage
The debug uart is 3.3V TTL power domain.
Reference Link
http://forum.banana-pi.org/
