Banana Pi BPI-P2 Pro
Revision as of 10:09, 18 August 2023 by Sinovoip (talk | contribs) (→Armbian)
BPI-9600 IEEE 802.3af PoE module(5V 2A)
Application direction
  • Maker DIY
  • IoT Smart Internet of Things
  • Intelligent speech recognition
  • Man-machine interface
  • Industrial control
  • Intelligent robot
  • CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308B-S
  • 512 DDR3 SDRAM
  • 8G eMMC flash onboard
  • WiFi (AP6256) & BT onboard
  • 40 PIN GPIO,includes UART, SPI, I2C, IO etc
  • 100M LAN
  • Audio: Supports rich audio interfaces ,Such as MIC/PDM/SPDIF/I2S
Getting Start with BPI-P2 Pro
SOC RockChip RK3308B-S
CPU Quad-core ARM Cortex-A35
GPU none
ROM 512MB
RAM 8GB ,eMMC
TF Card TF card (Max 64GB)
Network 100M LAN
PoE power PoE function support,Output Voltage 5V, Output Power 10W
WiFi AP6256
Audio Output With built-in audio CODEC, including ADC×8 and DAC×2
Power Source TYPE C 5V/2A or PoE power
USB 1xUSB 2.0
1xType-C
Others Fan、RTC、LED、debug
Low-level peripherals 40 Pin + 12 Pin
LED Power led & Status led
Product size 65mm X 52.5mm
Weight 30g
Memory \(SDRAM\) 512M 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
IR N/A N/A N/A N/A
Weight 30g 30g 15g 9g
40 Pin GPIO define
RK3308B-S SOC
Pin No.
Function3 Function2 Function1 Pin# Pin# Function1 Function2 Function3 RK3308B-S SOC
Pin No.
VCC_IO 1 2 VCC5V0_SYS
ADC_KEY_IN1 3 4 VCC5V0_SYS
69 I2S0_SCLK_TX GPIO2_A5 5 6 GPIO0_C1 SPDIF_TX 17
70 I2S0_SCLK_RX PDM_CLK GPIO2_A6 7 8 GPIO2_A7 I2S0_LRCK_TX 71
68 I2S0_8CH_MCLK I2S0_MCLK GPIO2_A4 9 10 GPIO2_B0 I2S0_LRCK_RX 72
73 I2S0_SDO0 GPIO2_B1 11 12 GPIO2_B5 PDM_SDI0 I2S0_SDI0 77
74 I2S0_SDO1 GPIO2_B2 13 14 GPIO2_B6 PDM_SDI1 I2S0_SDI1 78
75 I2S0_SDO2 GPIO2_B3 15 16 GPIO2_B7 PDM_SDI2 I2S0_SDI2 79
76 I2S0_SDO3 GPIO2_B4 17 18 GPIO2_C0 PDM_SDI3 I2S0_SDI3 80
GND 19 20 GND
LINEOUT_L 21 22 LINEOUT_R
MICBIAS1 23 24 MICBIAS2
MICP1 25 26 MICN1
MICP2 27 28 MICN2
MICP3 29 30 MICN3
MICP4 31 32 MICN4
MICP5 33 34 MICN5
MICP6 35 36 MICN6
MICP7 37 38 MICN7
MICP8 39 40 MICN8
12 PIN GPIO
RK3308B-S SOC
Pin No.
Function4 Function3 Function2 Function1 Pin# Pin# Function1 Function2 Function3 Function4 RK3308B-S SOC
Pin No.
65 UART0_TX SPI0_TX GPIO2_A1 1 2 GPIO0_B3 I2C1_SDA 11
64 UART0_RX SPI0_RX GPIO2_A0 3 4 GPIO0_B4 I2C1_SCL 12
56 SPI2_CS I2C0_SCL UART1_TX GPIO1_D1 5 6 VCC_IO
57 SPI2_CLK I2C0_SDA UART1_TX GPIO1_D0 7 8 GND
55 JTAG_TMS UART2_TX_M0 SPI2_TX GPIO1_C7 9 10 GPIO0_B7 PWM2 I2C3_SDA 15
54 JTAG_TCK UART2_RX_M0 SPI2_RX GPIO1_C6 11 12 GPIO0_C0 PWM3 IR_RX 16
PoE support
Baidu Cloud: https://pan.baidu.com/s/1AuWYgWQ8OBVPHfF-wdWaAA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1QC-3x8bdQePFz1z70rapNwB2Jlb5orvh?usp=sharing
Buildroot
  • Banana Pi BPI-P2 pro buildroot image update
Baidu cloud: https://pan.baidu.com/s/1V8ixOF8vdtuPvzjMGwOcjA?pwd=8888 (pincode:8888)
Google Drive:
  • Banana Pi BPI-P2 pro debian11 image update
Baidu Cloud: https://pan.baidu.com/s/1MSzcVKlOY_7Pi66-vhRZGw?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/file/d/1xQVWtE3-9BDMGWTp_mCNiGQd1w_7318t/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1s2D94VO78nglr3EFhKSukw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/16ra3x3nQlnrM1YCoWdvwYXRFYA4onOuK?usp=sharing
