Banana Pi BPI-CM2
Revision as of 00:34, 7 August 2023 by Sinovoip (talk | contribs) (BPI-CM2 Introduction)
Banana Pi BPI-CM2 with Rockchip RK3568
Banana Pi BPI-R2 Pro with Rockchip RK3568
Banana Pi BPI-CM4 with A311D design
Banana Pi BPI-CM4 with base board
Banana Pi BPI-CM5 with A311D2 design
Banana Pi BPI-CM5 with BPI-CM4 base board
Banana Pi BPI-CM4 with Raspberry Pi CM4 base board
Banana Pi BPI-CM2 is a computer module with Rockchip RK3568 Quad-core ARM Cortex-A55 CPU, Mali-G52 1-Core-2EE GPU,2GB LPDDR4/LPDDR4x ,8 G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.\
Rockchip RK3568 provides a wealth of interface resources. In addition to the board-to-board connectors compatible with the Raspberry PI, other interfaces are also drawn from the board-to-board interface, so that you can design your own base board and use of the rich interface resources of the RK3568
Banana Pi BPI-R2 Pro also with Rockchip RK3568,and Public sale long time,The software has been developed and is easy to use on BPI-CM2
Application direction
  • . Maker DIY
  • . Internet service gateway
  • . robot control
  • . Industrial control and industrial automation gateway
  • . Nas device
  • . Network and communication applications
  • 1. Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
  • 2. Mali-G52 1-Core-2EE GPU
  • 3. 2GB LPDDR4/LPDDR4x (Max 8G)
  • 4. 8G eMMC flash (Max 128G)
  • 14. support Android and Linux system.
  • 15. Size: 55x40mm
Getting Started with CM2
BPI-CM2 Module Hardware interface
BPI-CM2 Module PIN Out define
BPI-CM2 moudule base board interface
Banana Pi BPI-CM2 SBC specifications
Same size as RPI CM4
The BPI-CM4 computer module is exactly the same size as the raspberry PI CM4, and adopts the same interface,You can use the universal raspberry PI CM4 module expansion board.
but if you need use all BPI-CM2 interface, please use Banana Pi BPI-CM2 base board(designing now)
Third part image
