Banana Pi BPI-R3 Mini
Revision as of 17:37, 3 August 2023 by Sinovoip (talk | contribs) (Hardware spec)
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G/5G with MT7976C, support 2x 2.5GbE ethernet port.
Application direction
  • Internet service Router
  • Wireless Router
  • Wireless Repeater
  • Home security Gateway
  • Home Automation
  • Nas device
  • Soft router
  • Network and communication applications
  • MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
  • Wifi 6 2.4G/5G(MT7976C)
  • 2G DDR RAM
  • 8G eMMC flash
  • 128MB Nand flash
  • 2x 2.5GbE network port
  • 1x M.2 Key B USB interface
  • 1x M.2 KEY M PCIe interface
  • 1x USB2.0 interface
HardWare Specification of Banana pi BPI-R3 Mini
CPU MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53 chip design
SDRAM 2 GB DDR4
On board Storage Nand flash,8GB eMMC onboard
On board Network 2x 2.5GbE Ethernet
Wifi Wifi 6 2x2 2.4G Wifi + 3x3 5G Wifi(MT7976C)
1x M.2 Key B interface
M.2 Key M 1x M.2 KEY-M PCIe inerface
USB 1x USB 2.0
Buttons Reset button, boot switch
5 Leds Power ,System, Wifi 2G ,Wifi 5G ,4G Lte ,SSD
DC Power 20W/12V TypeC PD
Sizes
Weight 100g
SSD and 5G support
  • Opensource Driver BSP
https://github.com/BPI-SINOVOIP/BPI-R3MINI-OPENWRT-V21.02.3
  • BPI-R3 Mini DXF file
Google Drive: https://drive.google.com/file/d/1FgNVjR-kPdFVNZBPkAF8xTIZ4YauJ_2O/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1t1hZjNdg7rMBJcqVEZN-Ag?pwd=8888 (pincode:8888)
  • BPI-R3 Mini schematic diagram
Google Drive:https://drive.google.com/file/d/1wvovcYf0OtvQl5fekJku25QNeER1D7cM/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1HohHjd2w-mqLlBhwsXR87A?pwd=8888 (pincode:8888)
Release image
  • 2023-07-19 BPI-R3 Mini OpenWRT image with Opensource Driver BSP
Google Drive: https://drive.google.com/drive/folders/1Lf04fV3MW7XWssxHLLUlOaZmJh_lRLY5?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1dsDxsNPttjbqg-qr7bHNWA?pwd=8888 (pincode:8888)
  • 2023-07-19 BPI-R3 Mini OpenWRT image with MTK vendor driver, Not OpenSource Driver BSP
Google Drive:https://drive.google.com/drive/folders/1KC0GAiTLUc_TK2g4rUD2AWgN4DXKNn2x?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/17h7Ts80noZqwDUYYaVPFIQ?pwd=8888 (pincode:8888)
Accessories
