Getting Started with BPI-R3 MINI
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7976 and 5G wifi use MT7976, support 2 2.5GbE network port.
  • MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
  • Wifi 6 2.4G/5G(MT7976C)
  • 2G DDR RAM
  • 8G eMMC flash
  • 128MB Nand flash
  • 2x 2.5GbE network port
  • 1x M.2 Key B USB inerface
  • 1x M.2 KEY M PCIe inerface
  • 1x USB2.0 interface
 * Prepare USB-Serial interface
 * Using your USB-Serial Connect debug console on BPI-R3 MINI
  Note: Debug Uart 3.3v TTL
 *R3 boot switch Jumper Setting
  Note: EMMC Boot or Nand boot Support.
Warnning
 Note: Because BPI-R3 MINI can't support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device. if you want to update EMMC device, please boot from Nand, otherwise you update Nand device when it boot from EMMC.
 Anytime please confirm that one EMMC or Nand device include one bootable image, it's very important.
 Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
 1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
 2. Change boot switch Jumper, the board boot from Nand device, then power up the board.
 4. Execute following command to enable and copy image to EMMC device:
    * dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
 7. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device.
 1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk.
 2. Change boot switch Jumper, the board boot from EMMC device, then power up the board.
    * mtd erase /dev/mtd0
    * dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
 7. power off R3MINI board, remove u-disk driver, change bootstrap to boot from Nand device.
Network-Configuration
root@OpenWrt:/# ifconfig
         collisions:0 txqueuelen:1000
         Interrupt:124
         Interrupt:124
lo Link encap:Local Loopback
         Interrupt:6
root@OpenWrt:/#
  • echo 433(22+411) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio433/direction
  • echo 1 > /sys/class/gpio/gpio433/value
FAN
  • CN16 supports PWM control.
PWM FAN Control
  • echo 0 > /sys/class/pwm/pwmchip0/export
  • echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
  • echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
  • echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
  • echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
miniPCIe slot
4G/5G Module
  • BPI-R3 supports 4G LTE EC25, 5G Quectel RM500U-CN Series
Ap mode on BPI-R3
  • ra0 is MT7986a 2.4G wifi
  • rax0 is MT7986a 5G wifi
Wifi & Serial cable
  • If the chip type of serial cable is pl2303, the driver fails to load the firmware apparently and thus the wifi can't work.
  • Other types including cp2102,ch340 and FDTI are all available, serial cable vlotage must be 3.3v LVTTL standard.
  • MT7986a Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
TTL Voltage
The debug-uart TTL is tolerant to 3.3V.
Reference Link
http://forum.banana-pi.org/
