Getting Started with BPI-R3 MINI
Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7976 and 5G wifi use MT7976, support 2 2.5GbE network port.
- MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE network port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface * Using your USB-Serial Connect debug console on BPI-R3 MINI Note: Debug Uart 3.3v TTL![]()
*R3 boot switch Jumper Setting Note: EMMC Boot or Nand boot Support.
Warnning
Note: Because BPI-R3 MINI can't support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device. if you want to update EMMC device, please boot from Nand, otherwise you update Nand device when it boot from EMMC. Anytime please confirm that one EMMC or Nand device include one bootable image, it's very important.
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk. 2. Change boot switch Jumper, the board boot from Nand device, then power up the board. 3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * change your directory to the mounting point, here is : cd /mnt
4. Execute following command to enable and copy image to EMMC device: * echo 0 > /sys/block/mmcblk0boot0/force_ro * dd if=bl2_emmc.img of=/dev/mmcblk0boot0 * dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0 * mmc bootpart enable 1 1 /dev/mmcblk0
7. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device. Note: Enable EMMC device, boot strap is from EMMC.
Network-Configuration
root@OpenWrt:/# ifconfig
lo Link encap:Local Loopback
root@OpenWrt:/#
FAN
- CN16 supports PWM control.
PWM FAN Control
miniPCIe slot
4G&5G
- BPI-R3 supports 4G LTE EC25.
- If you want to use 5G on BPI-R3:
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Wifi & Serial cable
UART_TX0 is the Boot Strapping PIN and must be kept low during power-on.
TTL Voltage
