Banana Pi BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Allwinner R40/V40 Quad Core ARM Cortex A7 CPU
- 1GB DDR3 SDRAM.
- SATA Interface.
- 4*USB 2.0
- MIPI DSI ingerface
- CSI camera interface
| HardWare Specification of Banana pi BPI-M2 Berry | |||
| Soc | Allwinner R40/V40 | ||
| SDRAM | 1GB DDR3 with 733MHz\(shared with GPU\) | ||
| Bluetooth | BT4.0 | ||
| On board Storage | MicroSD \(TF\) card,No eMMC onboard | ||
| Audio outputs | HDMI, analog audio \(via 3.5 mm TRRS jack\), I2S audio \(also potentially for audio input\) | ||
| USB | 4 USB 2.0 host, 1 USB 2.0 OTG | ||
| IR | No onboard IR receiver | ||
| DC Power | 5V/2A with micro USB port | ||
| battery | No 3.7V lithium battery power support | ||
| Weight | 40g | ||
| 40 PIN GPIO of Banana pi BPI-M2 Ultra | |||
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P04 | DCIN | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P11 | UART7-TX | PI20 | |
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| ON1-P39 | GND | ||
| CSi Camera connector GPIO of Banana pi BPI-M2 Ultra | |||
| CN5-P01 | NC | ||
| CN5-P02 | GND | ||
| CN5-P04 | CSI0-AVDD | ||
| CN5-P10 | CSI0-DVDD | ||
| CN5-P11 | CSI0-DOVDD | ||
| CN5-P15 | GND | ||
| CN5-P16 | CSI0-D5 | PE9 | |
| CN5-P18 | CSI0-D4 | PE8 | |
| CN5-P19 | CSI0-D0 | PE4 | |
| CN5-P20 | CSI0-D3 | PE7 | |
| CN5-P21 | CSI0-D1 | PE5 | |
| CN5-P22 | CSI0-D2 | PE6 | |
| CN5-P23 | GND | ||
| CN5-P24 | CSI0-AFVCC | ||
Display specification
| CN6-P01 | VCC-3V3 | ||
| CN6-P02 | IPSOUT | ||
| CN6-P03 | VCC-3V3 | ||
| CN6-P04 | IPSOUT | ||
| CN6-P05 | GND | ||
| CN6-P06 | IPSOUT | ||
| CN6-P07 | GND | ||
| CN6-P08 | IPSOUT | ||
| CN6-P09 | NC | ||
| CN6-P10 | GND | ||
| CN6-P11 | NC | ||
| CN6-P12 | DSI-D0N | ||
| CN6-P13 | NC | ||
| CN6-P14 | DSI-D0P | ||
| CN6-P15 | NC | ||
| CN6-P16 | GND | ||
| CN6-P18 | DSI-D1N | ||
| CN6-P20 | DSI-D1P | ||
| CN6-P22 | GND | ||
| CN6-P24 | DSI-CKN | ||
| CN6-P25 | GND | ||
| CN6-P26 | DSI-CKP | ||
| CN6-P28 | GND | ||
| CN6-P30 | DSI-D2N | ||
| CN6-P32 | DSI-D2P | ||
| CN6-P33 | GND | ||
| CN6-P34 | GND | ||
| CN6-P35 | LCD-PWM | PB2 | |
| CN6-P36 | DSI-D3N | ||
| CN6-P37 | GND | ||
| CN6-P38 | DSI-D3P | ||
| CN6-P39 | NC | ||
| CN6-P40 | GND | ||
| CON4 Uart GPIO of Banana pi BPI-M2 Ultra | |||
| CON2 P03 | UART0-TXD | ||
| CON2 P02 | UART0-RXD | ||
| CON2 P01 | GND | ||
Opnewrt
TinaLinux
- Schematics BPI-M2 Berry Schematics
- Dimensional diagram BPI-M2 Berry dxf file
- Allwinner R40/V40 datasheet
- Banana pi BPI-M2 Berry CE,FCC,RoHS
- RPiTC v3 1.12 for PBI-M2 berry 2017-11-28 : 2017-11-28-RPiTCv3_1.12-preview-bpi-m2u-sd-emmc.img.zip
- Ubuntu-16.04-mate-desktop-beta2 2017-11-13 : 2017-11-13-ubuntu-16.04-mate-desktop-beta2-bpi-m2u-sd-emmc.img.zip
- Android 6.0 2017-08-25 for BPI-M2 Ultra & BPI-M2 Berry : Android 6.0 (Version:V1) 2017-08-25
