Banana Pi BPI-P2 Pro
Banana Pi BPI-P2 pro is a development board based on RK3308B-S chip developed by armsom company. With a high-performance 4-core ARM Cortex-A35 processor, it provides a high-performance external memory interface (16bit DDR2/DDR3/DDR3L/LPDDR2). The chip has a wealth of interfaces, such as I2S,PCM,TDM, I2C,UART,SPDIF,HDMI ARC, etc., to meet the application of different products. RK3308 has a rich voice interface, its own eight ADC interface, multi-channel I2S and multi-channel PDM interface. This not only provides customers with a wealth of interface choices, but also can reduce the hardware design difficulty and hardware design cost of products.
Banana Pi BPI-P2 Pro has 512MB DDR3 memory size, operating system and storage can use SD card or emmc. armsom-p2pro is available as an onboard storage version with 1Gb/2Gb/4Gb/8Gb NAND flash
  • CPU: 64bits Quad-core Arm Cortex-A35 Rockchip RK3308.
  • 2G LPDDR2 SDRAM.
  • 8G eMMC flash onboard.
  • WiFi (AP6255) & Bluetooth onboard.
  • 100M LAN
Getting Start with BPI-P2 Pro
Memory \(SDRAM\) 2G 512M DDR3(shared with GPU) 512M DDR3(shared with GPU) 512 MB DDR2
IR N/A N/A N/A N/A
Weight 30g 30g 15g 9g
PoE support
