Banana Pi BPI-W2
  • Mali T820 MP3 GPU
  • 2G DDR4 SDRAM
  • 2 SATA interface
  • 1XGigabit LAN 1x Gigabit WAN
  • HDMI in & HDMI out
  • Mini DP
HardWare Specification of Banana pi BPI-R2
Soc Realtek RTD1296 quad-core ARM A53
GPU Mali T820 MP3 GPU
Power 12V @ 2A via DC power
Features
Wifi/Bluetooth **Option** ,not support onboard WIFI & BT
On board Storage MicroSD \(TF\) card, 2 SATA 6Gbps ,eMMC,SIM card slot
Display HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP
HDMI Out/In 1\* HDMI out port and 1\* HDMI In port
USB 3.0 1x USB 3.0 host
Mini DP 1* Mini DP
TYPE C 1 type C interface
RTC battery RTC battery power interface
Leds Red, Green, Blue
Other IR reciever
Sizes 148 mm × 100.5mm
Weight 100g
BPI-W2 GPIO PIN define
Banana Pi BPI-W2 40-pin GPIO
GPIOPinName DefaultFunction Function2:GPIO
CON1-P02 5VD
CON1-P03 I2C5\_SCL GPIO13
CON1-P04 5VD
CON1-P05 I2C5\_SDA GPIO14
CON1-P07 PWM0\_0
CON1-P08 IGPIO3 |
CON1-P09 |
CON1-P10 IGPIO2 |
CON1-P11 GPIO17 |
CON1-P12 GPIO58 |
CON1-P13 GPIO25 |
CON1-P14 |
CON1-P15 GPIO27 |
CON1-P16 IGPIO5 |
CON1-P17 |
CON1-P18 IGPIO4 |
CON1-P19 GPIO7 |
CON1-P20 |
CON1-P21 GPIO4 |
CON1-P22 IGPIO9 |
CON1-P23 GPIO5 |
CON1-P24 GPIO6 |
CON1-P25 |
CON1-P26 GPIO8 |
CON1-P27 GPIO12 |
CON1-P28 GPIO11 |
CON1-P29 GPIO100 |
CON1-P30 |
CON1-P31 GPIO21 |
CON1-P32 GPIO54 |
CON1-P33 GPIO59 |
CON1-P34 |
CON1-P35 GPIO57 |
CON1-P36 GPIO22 |
CON1-P37 GPIO23 |
CON1-P38 GPIO24 |
CON1-P39 |
CON1-P40 GPIO60 |
| BPI-W2 Debug UART \(CON3\) | | | | :--- | :--- | :--- | | CON2-P1 | GND | | | CON2-P2 | UART0-RX | | | CON2-P3 | UART0-TX | |
