BPI-FSM8191D servo motor controller is an industrial-grade servo motor control product created by Bananapai open source community and Fortior technology. It is a servo module used to drive rotary servo motor, linear servo motor and torque motor. In practical applications, it is composed of main control board and power board, providing motor control core algorithm and various communication functions. BPI-FSM8191D servo module main control board, configured with two application ports and a power board interface, the servo module pin contains a number of signal interfaces, which can meet the debugging of most servo functions. In different application scenarios, the servo power board can be customized to provide power input and output, power supply and energy consumption requirements. The power board has a rich debugging interface, which fully meets the needs of developers for different power and power supplies.
Application direction
New energy industry: die cutting machine, laminating machine, cutting and laminating machine, pole ear welding, coating machine, shell machine, top welding, helium detector, liquid injection machine, forming cabinet, replenishing machine, sealing welding machine, parting cabinet, Pack line, etc.
Pulse & direction with electronic drive,serial ,serial RS232
status display
modality
Fase 7 LED (Red),Display drive status (alarm, running, enable, etc.)
electronic gear
method
User defined gear ratio
GUI
UI
base on Windows serial port software
function
Set connection, drive information, power information, motor, feedback, I/O selection/configuration, motion Settings/adjustments, fault history/status display, etc.
Rotate toward unit
position
pulse(Counts)
speed
per minute (rpm)
Acceleration/deceleration
rps/s
line unit
position
pulse(Counts)、mm
speed
mm/s
mm/s2
Servo module communication specifications
Communication specification
number
spec
RS232
base on modbus RTU
Baud rate: 19200 bit/s
Maximum conductor length: 10 m
High-Speed Serial (Specially used to observe waveforms)
Based on custom protocols
Baud rate: 115200 - 750000 bit/s
Maximum conductor length:2 m
Servo module I/O specifications
Item
standard
explain
analog input
voltage range
simulate ±10 VDC Finite difference
zero attenuation
100 Hz
bandwidth (-3 dB)
500 Hz
Pulse & Direction
signal
RS 422 line receiver
Maximum input frequency
1.6 MHz (will be increased to 5MHz in the future)
Digital input (8 channels)
signal
Configurable, light isolated, drain input.
(General IO configurable related pin function)
voltage
24 V
Maximum input current
10 mA
Transfer delay time
1 ms
Digital output (6 channels)
signal
voltage
24 V
40 mA
Transfer delay time
1 ms
Main I/O function signal
function
explain
input signal(Ports can be configured)
forward limit
Positive limit switch
Negative limit
Negative limit switch
Return Origin
Origin switch
Motor enable
External enable signal
ALM-RST
External clear alarm signal
speed limitation
Torque control with speed limit input
Output signal (port configurable)
Servo positioning complete
Servo execution positioning complete signal
SERVO stoped
Servo execution stop signal
SERVO ALARM
Servo error alarm signal
Servo brake
Servo brake control signal
Servo phase seeking complete
Servo phase seeking complete signal
Servo return to zero complete
Servo return to zero complete signal
Servo module supports motor feedback specifications
Supported motor feedback specifications
motor feedback
explain
summary
Driver output voltage
5 VDC
Maximum output current of the driver
250 mA
Maximum cable length
AWG 28 – 3 m; AWG 24 – 10 m
incremental encoder
signal
With (or without) a zero/hall signal AB quadrature signal encoder differential output
AB Orthogonal maximum input frequency
1.6 MHz (Orthogonality conditions) (It will be increased to 5MHz in the future)
Minimum zero pulse width
1 µs
Hall sensor
signal
single-ended
Sinusoidal encoder (will be added in next version)
signal
Sine-cosine difference, with or without Hall
signal level
1 Vpp @ 2.5 V
270 kHz
input impedance
120 Ω
interpolation
Max to 16384 (14 bit)
Effective interpolation
Max to 4096 (12 bit)
Motor signal feedback wire pin definition
The motor feedback interface is wired according to the type of feedback device used in practical applications. See the pin outlet table below for details.
The motor temperature sensor uses 12/25 pins and has been pulled up to 5V through the module interior.
Pin define
Module pin
function
Pin define
Module pin
function
incremental encoder A+
14
98
incremental encoder A-
SSI encoder data+
2
96
incremental encoder B+
15
95
incremental encoder B-
SSI encoder clock+
SSI encoder clock-
3
93
incremental encoder Z+
16
94
incremental encoder Z-
4
116
Hall U+
17
115
Hall V+
5
114
Hall W+
18
6
19
7
20
8
21
9
111
Sine encoder sine+
22
110
Sine encoder sine-
10
109
Sine encoder cosine+
23
108
Sine encoder cosine-
11
3、4
5V power
24
Common ground with module
ground(5V loop)
12
91
Motor temperature sensor
25
90
13
3、4
5V power
26
shield
Servo module I/O port pin definition
The digital/analog inputs and outputs are wired according to the requirements of your application. To keep the digital I/O isolated, the ground of your 24V loop is connected to pins 1 and 19, which drive the digital input pins and require you to provide a 24V signal.
Pin define
Module pin
function
explain
Pin define
Module pin
function
explain
Digital input to the public ground
user provides a 24V input signa ground
19
72
Digital output to the public ground
provides 24V pull-up ground
2
107
Equivalent encoder output Z+
Equivalent encoder output signal Z forward direction
20
84
RS485 ommunication input -
RS485 ommunication input -(Or B terminal)
3
21
83
485 input +
RS485 communication input +(Or A terminal)
4
106
Equivalent encoder output Z-
Equivalent encoder output signal Z negative
22
73
Digital input 8
Optically isolated programmable digital input 8
5
104
Equivalent encoder output B+
Equivalent encoder output signal B forward direction
23
74
Digital input 7
Optically isolated programmable digital input 7
6
24
75
Digital input 6
Optically isolated programmable digital input 6
7
105
Equivalent encoder output B-
Equivalent encoder output signal B negative
25
DGND
DGND
8
112
Analog input AN+
Diff forward direction of analog instruction input
26
76
Digital input 5
Optically isolated programmable digital input 5
9
103
Equivalent encoder output A-
Equivalent encoder output signal A negative
27
77
Digital input 4
Optically isolated programmable digital input 4
10
DGND
DGND
28
78
Digital input 3
Optically isolated programmable digital input 3
11
102
Equivalent encoder output A+
Equivalent encoder output signal A forward direction
29
DGND
DGND
12
113
Analog input AN-
Differential analog instruction input in negative direction
30
68
Digital output 3
Optically isolated programmable digital output, can be read with OUT3
13
DGND
DGND
31
65
Digital output 6
Optically isolated programmable digital output, can be read with OUT6
14
87
direction input -
Direction Indicates the negative direction of the input
32
69
Digital output 2
Optically isolated programmable digital output, can be read with OUT2
15
79
Digital input 2
Optically isolated programmable digital input,Read with IN2
33
80
Digital input 1
Optically isolated programmable digital input,Read with IN1
16
86
direction input +
Direction Indicates the positive direction of the input
34
70
Digital output 1
Optically isolated programmable digital output, can be read with OUT1
17
89
impulse input +
The pulse input is positive
35
66
Digital output 5
Optically isolated programmable digital output, can be read with OUT5
18
88
impulse input -
The negative direction of the pulse input
36
67
Digital output 4
Optically isolated programmable digital output, can be read with OUT4
Servo module protection function and use environment requirements
item
spec
Protection function
Overcurrent, undervoltage and overvoltage, overtemperature, missing feedback, STO signal not connected, position following error, speed over, parameter error, etc.
Anti-flying car protection function
When the motor is seeking phase, the external pulse input signal function (pulse & direction) and the receiving motion command function (RS232) are shielded to prevent motor accidents.
BPI-FSM8191D servo motor controller installation
General installation instructions
Follow the steps below to install and configure the driver module.
1.According to the required operating power, select the appropriate power base plate.
2.Complete all electrical links:
a)Install the servo module onto the module switching base plate
b)Connect the switching base plate to the power plate
c)motor
d)motor feedback
e)Safe torque switching (STO), or shorting with a jumper
f)IO control signal
g)AC input power supply
3.Connect the drive to the PC using a USB/232 cable.
4.Power drives and PC。
5.Connect to a fieldbus device (optional).
6.Open FortiorTechServoStudio.exe(no need installation ).
7.use FortiorTechServoStudio Configure and debug drives.
FortiorTechServoStudio testing software
FortiorTechServoStudio is a graphical user interface (GUI) that comes with the servo module to install, configure, and debug the drive. FortiorTechServoStudio can be used to debug drive parameters online and perform specific drive operations.
FortiorTechServoStudio support two methods for initial system configuration:
Using [General - Backup and Recovery], click "Default Parameters" to complete the initial parameter configuration, then configure the motor parameters in [Motor], and configure the encoder resolution in [Feedback].
With [General - Backup and Recovery], the motor "Import Parameters" import previously configured motor parameter data.
FortiorTechServoStudio main interface consists of 5 functional areas:
1.Toolbar, containing common quick function buttons。
Offline|Online – Toggle FortiorTechServoStudio online/offline and display the connection status. See section [Drive Online and Offline] 。
Enable|Disable – Enable/disable the drive and display the enable status of the drive
Save – Saves the parameters in the current drive RAM to the drive memory. It is recommended to use the Save button after configuring parameters to save parameter values in memory.
No FLT — Clear drive faults. This bit turns red when the drive fails, and the motor can clear the fault.
2.information bar:
Stop —Stop the motor and disable the drive.
Help —FortiorTechServoStudio software online help. This feature is not enabled in this version of the software.
About —Information about the software version. In this version, the function is not available.
