香蕉派 BPI-R4
概要
BPI-R4介绍
Banana Pi BPI-R4 Router board with MediaTek MT7988A (Filogic 880) quad-core ARM Corex-A73 design ,4GB DDR4 RAM,8GB eMMC,128MB SPI-NAND flash onboard, also have 2x 10Gbe SFP, 4x Gbe network port,with USB3.2 port,M.2 support 4G/5G/NVME SSD.2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card). It is a very high performance open source router development board.
联发科(MediaTek) MT7988(Filogic 880)芯片介绍
Mediatek Filogic 880. the 36Gbps Wi-Fi 7 access point/router/gateway platform delivers the fastest and most reliable connection experience
The MediaTek MT7988A is a world-Leading network processing platform for high-performance and reliable networking experiences,both in wired and wireless applications. The MT7988A comprises a rich connection interface sets include 4 Gigabit Ethernet ports. 2 US下GMII interfaces. 4 PCIe Interfaces,and 2 USB 3.2 en1 Ports
the MT7988A further enables seamless Wi-Fi 7 tri-band,2.4 GHz.5 GHz and 6 GHz,connectivity,with its Wi-Fi 7 companion chip that features 320-MHz bandwidth,4096-QAM ,MLO,MRU,and AFC.
To answer the need of fast-evolving tunneling applications,the MT7988A comes with MediaTek Tunnel offload processor System(TOPS),which facilitates the processing of a wide range of tunneling protocols.The MT7988A optimizes networking performance with exquistitely tuned ISA of MediaTek TOPS,and is dedicated to lifting networking offloading performance to premium level.
应用场景
- Internet service Router
- Wifi 7 Wireless Router
- 4G/5G Wireless Router
- Wireless Repeater
- Home security Gateway
- Home Automation
- Nas device
- Network and communication applications
- MediaTek MT7988A (Filogic 880) quad-core Arm Corex-A73,1.8GHz processor
- 4GB DDR4
- 8GB eMMC flash
- 128MB SPI-NAND Flash
- Micro SD card slot
- 2x 10Gbe SFP slot (option 1x 10Gbe SFP and 1x SOC embedded 2.5Gbe PHY)
- 4x Gbe network port
- 1x USB3.2 slot
- 1x M.2 KEY-B slot with USB3.2 interface for 5G
- 1x M.2 KEY-M slot with PCIe3.0 1lane interface for NVME SSD
- 2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card)
- 26 PIN GPIO Header for expanding application
快速上手及开发
硬件接口示意图
WiFi7 iPA 网口模块支持
BPI-R4 wifi 7 modue use MediaTek MT7996+MT7995+MT7977A+MT7977B chip design
| HardWare Specification of Banana pi BPI-R4 | |||
| CPU | MediaTek MT7988A (Filogic 880) quad-core Arm Corex-A73,1.8GHz processor | ||
| SDRAM | 4 GB DDR4 | ||
| On board Network | 4 Port 10/100/1000Mbps Ethernet | ||
| SFP | 2x10G SFP or 1x10G SFP and 1x 2.5GbE | ||
| Wifi | Wifi6/Wifi 7 | ||
| mini PCIE | 2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi 7 NIC (Network Interface Card) | ||
| M.2 interface | 1x M.2 KEY-B slot with USB3.2 interface for 5G,1x M.2 KEY-M slot with PCIe3.0 1lane interface for NVME SSD | ||
| USB | 1xUSB 3.2 slot | ||
| DC Power | 12V/5.2A or 19V 3.2A | ||
| Weight | 250g | ||
参考资料
软件源代码
参考文档及资料
- Banana Pi BPI-R4 main block: https://drive.google.com/file/d/1Jm1Ai2NrIiy2dR9hgKkcOAZ1OUB40RdN/view?usp=sharing
- kernel [PATCH net-next 8/8] net: ethernet: mtk_eth_soc: add basic support for MT7988 SoC:https://www.spinics.net/lists/kernel/msg4821673.html
- [PATCH 15/15] dt-bindings: net: dsa: mediatek,mt7530: add mediatek,mt7988-switch:https://lore.kernel.org/lkml/80a853f182eac24735338f3c1f505e5f580053ca.1680180959.git.daniel@makrotopia.org/
- Discuss on forum :https://forum.banana-pi.org/t/banana-pi-bpi-r4-wifi-7-router-board-with-mediatek-mt7988a-filogic-880-4g-ram-and-8g-emmc/15757
