BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit PIN define
| HardWare Specification of Banana pi BPI-M2 zero | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pin Name | Analog Function1 | Analog Function2 | Function1 | Function2 | Power | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| P3 | ADC2_CH4 | GPIO13 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| P0 | ADC2_CH8 | DAC_1 | GPIO25 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| P4 | ADC2_CH3 | GPIO16 | P5 | ADC1_CH7 | GPIO35 | P6 | ADC2_CH5 | GPIO12 | P7 | ADC2_CH6 | GPIO14 | P1 | ADC1_CH4 | GPIO32 | P8 | GPIO16 | P9 | GPIO17 | P10 | ADC2_CH9 | DAC_2 | GPIO26 | P11 | ADC2_CH7 | GPIO27 | P12 | ADC2_CH2 | GPIO02 | P2 | ADC1_CH5 | GPIO33 | P13 | GPIO18 | SPI_SS | P14 | GPIO19 | SPI_SCK | P15 | GPIO23 | SPI_MISO | P16 | GPIO05 | SPI_MOSI | 3V3 | POWER:3V3 | 3V3 | POWER:3V3 | 3V3 | POWER:3V3 | P19 | GPIO22 | I2C_SCL | P20 | GPIO21 | I2C_SDA | GND | GROUND | GND | GROUND | GND | GROUND | ||||||
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | SPI SPEED | 40NHz | |
| 2 | SPI MODE | DIO | |
| 3 | FLASH SIZE | 32Mbit | |
| 4 | COM | COMx(Fill in the port number assigned by the computer) | |
| 5 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
