Banana Pi BPI-W2
  • Mali T820 MP3 GPU
  • 2G DDR4 SDRAM
  • 2 SATA interface
  • 1XGigabit LAN 1x Gigabit WAN
  • HDMI in & HDMI out
  • Mini DP
BPI-W2 hardware spec
Specification of Banana pi BPI-R2 |
Soc Realtek RTD1296 quad-core ARM A53
GPU Mali T820 MP3 GPU
Power 12V @ 2A via DC power
Features
**Option** ,not support onboard WIFI & BT
1 RGMII interface with PIN |
MicroSD \(TF\) card, 2 SATA 6Gbps ,eMMC,SIM card slot |
HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP |
The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. |
Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing |
support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in |
1\* HDMI out port and 1\* HDMI In port |
HDMI, I2S audio,Audio micro out, Audio out/in with PIN define |
1 pcie 2.0 interface |
1 pcie 1.1 and SDIO interface |
1x USB 3.0 host |
2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN |
1\* M.2 interface |
1\* Mini DP |
1 type C interface |
RTC battery power interface |
Reset button, Power button, U-boot button |
Red, Green, Blue |
IR reciever |
148 mm × 100.5mm |
100g |
