Banana Pi BPI-M64
[hide]Introduction
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
- Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
- 2 GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
- MIPI LCD interface
- Camera interface
- How to burn image : Quick Start Banana pi SBC
- How to burn Linux image to BPI-M64: https://forum.banana-pi.org.cn/t/topic/7210
- how to development: Getting Started with M64
HardWare Specification of Banana pi BPI-M64 | |||
CPU | Allwinner 64 Bit Quad Core ARM Cortex A53 1.2 GHz CPU | ||
GPU | Dual core Mali 400 MP2 GPU | ||
Memory | 2GB LPDDR3 (shared with GPU) | ||
Storage | MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB | ||
Network | 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth 4.0 | ||
Video Input(s) | A CSI input connector allows for the connection of a designed camera module | ||
Video Output(s) | 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities) | ||
Audio Input(s) | On board microphone | ||
Audio Output(s) | 3.5mm jack and HDMI | ||
USB ports | USB 2.0 PORT (x2), USB OTG (x1) | ||
Remote | IR Receiver | ||
LED | Power Status and 8P8C | ||
Power Source | 5 volt @2A via DC Power and/or Micro USB (OTG) | ||
OS | Android and Linux |
Banana Pi BPI-M64 has a 40-pin GPIO header . Following is the Banana Pi GPIO Pinout:
40 PIN GPIO of Banana pi BPI-M64 | |||
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P03 | TWI1-SDA | PH3 | |
CON2-P04 | VCC-5V | ||
CON2-P05 | TWI1-SCK | PH2 | |
CON2-P06 | GND | ||
CON2-P07 | PH6 | PH6 | |
CON2-P08 | UART2-TX | PB0 | |
CON2-P09 | GND | ||
CON2-P10 | UART2-RX | PB1 | |
CON2-P11 | PH7 | PH7 | |
CON2-P12 | UART2-CTS | PB3 | |
CON2-P13 | DMIC-CLK | PH10 | |
CON2-P14 | GND | ||
CON2-P15 | DMIC-DIN | PH11 | |
CON2-P16 | UART2-RTS | PB2 | |
CON2-P17 | VCC-3V3 | ||
CON2-P18 | PD4 | PD4 | |
CON2-P19 | SPI1-MOSI | PD2 | UART4-TX |
CON2-P20 | GND | ||
CON2-P21 | SPI1-MISO | PD3 | UART4-RX |
CON2-P22 | PC0 | PC0 | |
CON2-P23 | SPI1-CLK | PD1 | UART3-RX |
CON2-P24 | SPI1-CS | PD0 | UART3-TX |
CON2-P25 | GND | ||
CON2-P26 | PC2 | PC2 | |
CON2-P27 | PC4 | PC4 | |
CON2-P28 | PC3 | PC3 | |
CON2-P29 | PC7 | PC7 | |
CON2-P30 | GND | ||
CON2-P31 | PCM0-BCLK | PB5 | |
CON2-P32 | PCM0-DIN | PB7 | |
CON2-P33 | PCM0-SYNC | PB4 | |
CON2-P34 | GND | ||
CON2-P35 | PCM0-DOUT | PB6 | |
CON2-P36 | PL9 | PL9 | |
CON2-P37 | PL12 | PL12 | |
CON2-P38 | PL7 | PL7 | |
CON2-P39 | GND | ||
CON2-P40 | PL8 | PL8 |
CSI camer PIN define of Banana pi BPI-M64 | |||
CN5-P01 | NC | ||
CN5-P02 | GND | ||
CN5-P03 | CSI0-SDA | PE13 | |
CN5-P04 | CSI0-AVDD | ||
CN5-P05 | CSI0-SCK | PE12 | |
CN5-P06 | CSI0-Reset | PE16 | |
CN5-P07 | CSI0-VSYNC | ||
CN5-P08 | CSI0-PWDN | PE17 | |
CN5-P09 | CSI0-HSYNC | PE2 | |
CN5-P10 | CSI0-DVDD | ||
CN5-P11 | CSI0-DOVDD | ||
CN5-P12 | CSI0-D7 | PE11 | |
CN5-P13 | CSI0-MCLK | PE1 | |
CN5-P14 | CSI0-D6 | PE10 | |
CN5-P15 | GND | ||
CN5-P16 | CSI0-D5 | PE9 | |
CN5-P17 | CSI0-PCLK | PE0 | |
CN5-P18 | CSI0-D4 | PE8 | |
CN5-P19 | CSI0-D0 | PE4 | |
CN5-P20 | CSI0-D3 | PE7 | |
CN5-P21 | CSI0-D1 | PE5 | |
CN5-P22 | CSI0-D2 | PE6 | |
CN5-P23 | GND | ||
CN5-P24 | CSI0-AFVCC |
MIPI DSI display PIN define of Banana pi BPI-M64 | |||
CN6-P01 | VCC | ||
CN6-P02 | IPSOUT | ||
CN6-P03 | VCC | ||
CN6-P04 | IPSOUT | ||
CN6-P05 | GND | ||
CN6-P06 | IPSOUT | ||
CN6-P07 | GND | ||
CN6-P08 | IPSOUT | ||
CN6-P09 | NC | ||
CN6-P10 | GND | ||
CN6-P11 | NC | ||
CN6-P12 | DSI-D0N | ||
CN6-P13 | NC | ||
CN6-P14 | DSI-D0P | ||
CN6-P15 | NC | ||
CN6-P16 | GND | ||
CN6-P17 | TWI0-SDA | PH1 | |
CN6-P18 | DSI-D1N | ||
CN6-P19 | TWI0-SCK | PH0 | |
CN6-P20 | DSI-D1P | ||
CN6-P21 | CTP-INT | PH4 | |
CN6-P22 | GND | ||
CN6-P23 | CTP-RST | PH8 | |
CN6-P24 | DSI-CKN | ||
CN6-P25 | GND | ||
CN6-P26 | DSI-CKP | ||
CN6-P27 | LCD-BL-EN | PD5 | |
CN6-P28 | GND | ||
CN6-P29 | LCD-RST | PD6 | |
CN6-P30 | DSI-D2N | ||
CN6-P31 | LCD-PWR-EN | PD7 | |
CN6-P32 | DSI-D2P | ||
CN6-P33 | GND | ||
CN6-P34 | GND | ||
CN6-P35 | LCD-PWM | PL10 | |
CN6-P36 | DSI-D3N | ||
CN6-P37 | GND | ||
CN6-P38 | DSI-D3P | ||
CN6-P39 | NC | ||
CN6-P40 | GND |
Uart PIN define of Banana pi BPI-M64 | |||
CON2 P03 | UART0-TXD | PB8 | |
CON2 P02 | UART0-RXD | PB9 | |
CON2 P01 | GND |
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
BPI-M64 for Win10 IoT : https://catalog.azureiotsolutions.com/details?title=Allwinner_Banana_Pi_BPI_M64&source=all-devices-page
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
Windows 10 IoT Core for BPI-M64 Release Note
This document describes how to build AllWinner UEFI Firmware and bring a AllWinner dev board up with it. The AllWinner UEFI Firmware, as the major boot system for AllWinner-Windows platform, is based on the EDK2 framework which is open-source and with some AllWinner platform software packages injected.
Some updates:
- 1. Update the OS version to build v.10.0.15063.0 \(Creators Update\)
- 2. New page style of Device Portal, visit [1](https://deviceipaddr:8080) to check it
- 3. Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
- 4. Support on-screen keyboard, need to be enabled in Device Portal
- 5. Enable 100M Ethernet and fix some bugs
- 6. Support built-in UART bus in A64 SoC\(not built in the ffu, later provide driver binary and deployment helper\)
- 7. Support built-in IR module in A64 SoC\(not built in the ffu, later provide source code and dev doc for developers in community\)
Known Issues:
- Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable : Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
- An PnP bug in audio device may cause a blue screen when acting software shutdown
- Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: https://github.com/Leeway213/BSP-aw1689
And also some driver source code here with A64 datasheet in readme: https://github.com/Leeway213/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
Microsoft Azure IoT
- we have test BPI-M64 with Microsoft Azure IoT with aarch64 Ubuntu 18.04 Linux
- Microsoft Azure IoT Edge using DPS with TPM 2.0 SLB9670 : https://www.youtube.com/watch?v=k9_GSQgKlqk&feature=youtu.be
- Microsoft Azure IoT Edge using DPS with TPM 2.0 ST33 i2c : https://www.youtube.com/watch?v=2MrO1-esjwI&feature=youtu.be
- BPI-M64 Android 7 source code
- download link : https://github.com/BPI-SINOVOIP/BPI-A64-Android7
- BPI-M64 Android 6.0.1 source code
- download link : https://drive.google.com/open?id=0B_YnvHgh2rwjdTRVRVFaSHd2cnc
- BPI-M64 (allwnner A64) Linux 4.4 source code
- BPI-M64 Linux kernel 3.4 BSP code:
- github link : https://github.com/BPI-SINOVOIP/BPI-M64-bsp
- BPI-M64 Win10 IoT source code
- BPI-M64 Robot Operating System (ROS):
documents
- schematic diagram:
- google driver :google driver
- baidu cloud : http://pan.baidu.com/s/1kVRpcYb
- DXF file google download link :https://drive.google.com/file/d/0B4PAo2nW2KfnajlEY0xsdjNxY3c/view?usp=sharing
- Allwinner A64 chip datasheet:https://drive.google.com/file/d/0B4PAo2nW2KfnSW9lQnZ0d1RoVW8/view?usp=sharing
- Allwinner A64 user’s manual (720 pages):https://drive.google.com/file/d/0B4PAo2nW2KfnNHk4dkFJZEdqYXc/view?usp=sharing
- AXP803 Datasheet V1.0.pdf :https://drive.google.com/file/d/1nRbP1T02KlNZBbTJx4BHW5wVWvQPmDxC/view?usp=sharing
- A64 chip linux-sunxi wiki:http://linux-sunxi.org/A64
- BPI-M64 linux-sunxi wiki: https://linux-sunxi.org/Banana_Pi_M64
- Recording: burning the linux image to EMMC on M64 for the first time:https://forum.banana-pi.org/t/recording-burning-the-linux-image-to-emmc-on-m64-for-the-first-time/15477
- other document about allwinner A64 chip:http://bundie.neterra.net:8080/a64/
- battery interface spec : https://drive.google.com/file/d/0B4PAo2nW2KfnSmVuVDhQc0NLdG8/view?usp=sharing
- BPI-M64 quality guarantee
- BPI-M64 BT Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64bt40labtest.html
- BPI-M64 WIFI Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m264wifilabtest.html
- BPI-M64 Validation test : https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64validationtestreport.html
- CE FCC RoHS : http://forum.banana-pi.org/t/bpi-m64-ce-fcc-rohs-certification/2747
Amazon AWS Greengrass
Banana Pi BPI-M64 passed Amazon AWS Greengrass:https://devices.amazonaws.com/detail/a3G0h000000OvPoEAK/Banana-Pi-BPI-M64
How to install the Android image
- 2020-07-10 update, Android 7.1, base on kernel 3.10
- 2018-10-24 update Android 6.0 & 7.0 & 8.1, based on kernel 3.10.
- M64 Android 6.0 HDMI & LCD7
- Features Map: http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
- HDMI Version Image Links:
- Google Drive : https://drive.google.com/open?id=1Em7ZXVvbJI7wMXy_TM4VNwHo6Oa-vVBc
- Baidu Drive : https://pan.baidu.com/s/1ZginIvO3LVakqokIZAX1Xw
- LCD7 Version Image Links:
- Google Drive : https://drive.google.com/open?id=1Tts1krZyzwz9mL90j1ilTzVrJm6hh_J4
- Baidu Drive : https://pan.baidu.com/s/1oKMx_Ml5K1Jv7-qeS-NMsQ
- M64 Android 7.0 HDMI & LCD7
- Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_7.0
- Google Drive : https://drive.google.com/open?id=1mvKyK6KuPixs-jLD0FocIaV465bJ1Eig
- Baidu Drive : https://pan.baidu.com/s/15b32TXdh6752c-GBnR-Zeg
- Google Drive : https://drive.google.com/open?id=16Ffc5xiZgD7JYgrMtCGaOYLCuZdQGcnY
- Baidu Drive : https://pan.baidu.com/s/1a9RYKSTRhCO-UzFfIoGCtQ
- BPI-M64 Android 8.1 HDMI & LCD7
- Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
- Google Drive : https://drive.google.com/open?id=1UBaH9CNbmC9-n3jGImrFIAPZ8aZhqMJz
- Baidu Drive : https://pan.baidu.com/s/1lz57HrqNHx6f_Q6nk0oZvA
- Google Drive : https://drive.google.com/open?id=1wktuCcvolfozMFkLmugfZtGziHDj-1EM
- Baidu Drive : https://pan.baidu.com/s/1MteYqyBp8LeECjcDteCTZQ
- Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-android-6-0-7-0-8-1-release-2018-10-24/7107
- 2018-9-17 update android 6.0
- Features Map :http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
- Google Drive : https://drive.google.com/open?id=19ExJ9Ztfy3UgK9NZ4SiaVZAMozgyCJl7
- Baidu Drive : https://pan.baidu.com/s/1s_orgiEI7JU_hUgjnpd25w
- Google Drive : https://drive.google.com/open?id=1gWD_IT0P4NvdeqtK5I4MnJjwzsP7SXJc
- Baidu Drive : https://pan.baidu.com/s/1K0HYPiQe6nGvAS5bAAFHow
- Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
- 2018-08-17 update,android 8.1
- This release is for banana pi M64 board which is based on Allwinner A64, We have two images release,Android 8.1 is based on kernel 4.9
- BPI-M64 Android 8.1 Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
- HDMI-LCD-Version:
- Google Drive : https://drive.google.com/open?id=11XjvTAbPw57R6H5kL27GVXry4xu18dVs
- Baidu Drive : https://pan.baidu.com/s/1PQgJCUo6cY3wWxJ7rZrk-A
- Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-a64-new-image-android-8-1-ubuntu-release-2018-08-17/6531
- 2018-05-20 update ,android 7.0
- hdmi-Version and Lcd 5.0 version
- baidu cloud : https://pan.baidu.com/s/1O3PsI73WmFFvhxMmzEscIQ
- 2017-05-11 update ,android 6.0
- HDMI-Version
- Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
- Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
- MD5: f85281213b9c5b88008a487dd1b6963c
- LCD-Version
- Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
- Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
- MD5:be27e4eced96d3de81d46e512fd978eb
- forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
How to install BPI Linux Image
- 2020-08-26 update, Ubuntu Mate 18.04, Ubuntu Server 16.04, Raspbian Stretch, base on kernel 4.4
- 2020-04-21 update, Rasbian Stretch, Ubuntu 16.06 Mate Desktop, Ubuntu 16.06 Server and Ubuntu 18.04 Mate Desktop, base on kernel 4.4
- google drive:https://drive.google.com/drive/folders/0B_YnvHgh2rwja3I4SllZN2VkYm8
- baidu cloud:https://pan.baidu.com/s/18XH8_uusUGBusbp4xw4txQ Pincode:36R0
- 2018-11-02 update, based on kernel 3.10 & kernel 4.4.
- BPI-M64 Ubuntu 16.04 Desktp
- Features Map: http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
- Google Drive : https://drive.google.com/file/d/1YzdkY8i-IsXzXLkbPCPNbAuhYbHmUwgv/view
- Baidu Drive : https://pan.baidu.com/s/1XhOJBQtPkhvidjgipFNdzg
- md5sum : 3564f0d3de9936aa26b93eaf027703a0
- BPI-M64 Ubuntu 16.04 AARCH64 Kernel 3.10
- Features Map : http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_aarch64_16.04
- Google Drive : Chttps://drive.google.com/file/d/1MglySZLvquRPu1Wj8oLwdKBkFnRzLUL-/view
- Baidu Drive : https://pan.baidu.com/s/1_ZTDCuL9QZf6qrqaE4gbgQ
- md5sum : 7422e02daa01bff6de808490e89b436e
- BPI-M64 Ubuntu 16.04 AARCH64 Kernel 4.4
- features Map:http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89
- Google Drive : https://drive.google.com/file/d/1g_m1NLn1-wUQ8jjPKEAwQcSj4d4P9vRP/view
- Baidu Drive : https://pan.baidu.com/s/1JmKQGRKvJ9DwL_ij0K79FA
- md5sum : ea9bba6ab7fc78f7b8478bfd013a9b50
- Debian 9.5 AARCH64 Kernel 3.10
- Features Map: http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
- Image Links: Google Drive : Coming soon
- Baidu Drive: https://pan.baidu.com/s/1DJd7CGAT0NiijKfOBq9J4Q
- md5sum: 71fe25c1922c7f9ef81bb88e0f544de6
- 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
- image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
- Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
- MD5: 4b7e163d260e58a39ba8905e7ed39943
- Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
- 2018-09-18 This release is for banana pi M64 board which is based on Allwinner A64, We release three Images, Ubuntu 16.04 Desktop & Android is based on kernel 3.10.
- Features Map :http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
- Google Drive :
- Baidu Drive : https://pan.baidu.com/s/1wANJ4SwfNwKtBcd02WcbWA
- forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
- 2018-08-17 update Ubuntu 16.04 Server kernel 3.10.105
- 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
- baidu cloud: http://pan.baidu.com/s/1pLkbdTT
- MD5: ae34baa840874276858d936a7ca85c4f
- Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
- 2022-09-07 Armbian_22.11.0-trunk_Bananapim64_bullseye_edge_5.19.7_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1UUbn24l3q_OsVP4XWT6eVQN531tHPzX0/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1vFR9sUR0FhWgS1pemk9lTg?pwd=ina6 (pincode: ina6)
- 2018-11-2 update , This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Debian 9.5 AARCH64 is based on kernel 3.10 & kernel 4.4.
- M64 Debian 9.5 AARCH64 Kernel 3.10
- Features Map : * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
- Google driver : https://drive.google.com/file/d/10qGv2gVrSgwXMBLDsCF0nQFc9EJnnkeS/view
- Baidu Drive : https://pan.baidu.com/s/1DJd7CGAT0NiijKfOBq9J4Q
- md5sum : 71fe25c1922c7f9ef81bb88e0f544de6
- M64 Debian 9.5 AARCH64 Kernel 4.4
- Features Map: * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
- Google Drive : https://drive.google.com/file/d/17fh3YY6cwOzHMsqwnRQRTu9cXjKU4_tV/view
- Baidu Drive : https://pan.baidu.com/s/1sOR6WFz2U9MT0ltq6zYnJA
- md5sum : f3c2391b0232178018fda7ebfd64b14c
- forum pthread:http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-debian-9-5-aarch64-release-2018-11-02/7166
- 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
- Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
- baidu cloud:http://pan.baidu.com/s/1eSeTQeA
- MD5: 9ddf067457ebaf193de63c5c7141446a
- Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
- Armbian_23.02.0-trunk_Bananapim64_jammy_current_5.15.93.img.xz
- Armbian_23.02.0-trunk_Bananapim64_jammy_edge_6.1.11_xfce_desktop.img.xz
- 2022-09-07 Armbian_22.11.0-trunk_Bananapim64_jammy_edge_5.19.7_xfce_desktop.img
- Google Drive:https://drive.google.com/file/d/1_BaSpSdIaxJYy-QjaXLsOrJ25Ja7vA78/view?usp=sharing
- Baidu Cloud:https://pan.baidu.com/s/1uOex7pm2tPhfJ47hoXIuGA?pwd=7hms (pincode: 7hms)
- Armbian Image is base on Linux Mainline kernel
Raspbian
- 2018-11-06 update : This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Raspbian 9.4 is based on kernel 3.10 & kernel 4.4.
- BPI-M64 Raspbian 9.4 Kernel 3.10
- Features Map : http://wiki.banana-pi.org/M64_Image_Map#Raspbian_9.4_AARCH64
- Google Drive : https://drive.google.com/file/d/1qoKCVDgiuEj0IVEzuPgzuFLjFR9hTLH8/view
- Baidu Drive : https://pan.baidu.com/s/1MlIzQRpjs_soBDXOKf8NAw
- md5sum : e321c6dbb096a0348fceb9d4a0b6c210
- BPI-M64 Raspbian 9.4 Kernel 4.4
- Features Map : http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89_4
- Google Drive : https://drive.google.com/file/d/1WnsHKnbI_FWQVkHQmbCcJ3yJ38oWaHGy/view
- Baidu Drive : https://pan.baidu.com/s/1Bu-xiqiYsnau_xZp8-QEkw
- md5sum : 1d4f00680e6869e2c4e66e205e61d93d
- forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-raspbian-9-4-kernel-3-10-4-4-release-2018-11-06/7195
Fedora Linux
- BPI-M64 fedora image download(not support desktop): fedora 31 with grub (u-boot-2019.07 + kernel 5.3.0)
Manjaro
- 2019-01-15 update,BananaPi BPI-M64 Support Run Manjaro AArch64 System
- Baidu Drive: https://pan.baidu.com/s/18drwPBFKAzf4lFe6IPjaPA
- Google Drive: https://drive.google.com/open?id=1Lu8xw4sAVyiHJT4eYcolNTAIKG154gm6
- Bpi Ftp Server: https://dev.banana-pi.org.cn/Image/BPI-M64/Manjaro/
- md5sum : 8c9964fbd80836228c72fa205eb62f78
- username: manjaro/root
- password: bananapi
- Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-new-image-manjaro-aarch64-system-2019-01-16/7696
FreeBSD
Clonezilla
- Clonezilla support arm64 (Banana Pi BPI-M64),Thanks to Steven Shiau (NCHC Free Software Labs in Taiwan) & https://clonezilla.org/ 1, this image just for test .
- image download:https://drive.google.com/file/d/15oj0RjoU1TPC-jOXJ2bfhLb3vAiMf7p2/view
- discuss on forum: http://forum.banana-pi.org/t/bpi-m64-new-image-clonezilla-support-arm64-on-bpi-m64/10789
Others
- others image ,you can download at forum : http://forum.banana-pi.org/c/BPI-M64/M63image
Win 10 IoT
- 2017-1-13 updae Win10 IoT Core beta0.2
- baidu cloud :http://pan.baidu.com/s/1c2ce100
- Win10 IoT Core 10586 beta0.1
- download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
- baidu link : http://pan.baidu.com/s/1dEQyGgD
- MD5: 1c09118cd45bf0c3b61d1846710a3649
- BPI-M64 win10 IoT: https://catalog.azureiotsolutions.com/details?title=Allwinner_Banana_Pi_BPI_M64&source=all-devices-page
- 1,How-to use ubuntu system to support lcd7**?
- 1."vi /media/pi/BPI-BOOT/bananapi/bpi-m64/linux/lcd7/uEnv.txt"
- 2.If you use HC070TG lcd7 screen, change "touch=gt9xxnew_ts" But if you use S070WV20 lcd7 screen, you don't need to change.
- 3. "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-lcd7-8k.img.gz"
- 4.reboot
- For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M64
