Banana Pi BPI-R2
Revision as of 03:04, 5 September 2022 by Sinovoip (talk | contribs) (Documents)
Banana Pi BPI-R64 with MT7622
BPI-R2 smart router design
BPI-R2 with acrylic case
4G module via USB
BPI-R2 integrate a Quad-code ARM Cortex-A7 MPcore operating up to 1.3GHz, The Router also includes a variety of peripherals, including HDMI TX, MIPI DSI, PCIe2.0, USB2.0 OTG, USB3.0 Port, SATA port,5 Gbps Port Gigabit Ethernet port, 802.11a/b/g/n wifi & BT4.1 onboard, also support 802.11ac/n WLAN connection thru mini PCI-e port
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface.
  • support 2 SATA interface
Hardware Revision
Banana Pi R2
GPU Mali 450 MP4 GPU
Memory 2G DDR3 SDRAM
Audio Output(s) HDMI & I2S
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 148p;mm × 100.5mm 100g same ase Banana Pi BPI-R64 and Banana Pi BPI-R3
we have design a MT7615 802.11 ac wifi module ,can use on BPI-R2
BPI-R2 GPIO Pin define
BPI-R2 40 PIN GPIO define:
CON1-P02 VCC-5V
CON1-P03 I2C\_SDA0 GPIO75
CON1-P04 VCC-5V
CON1-P05 I2C\_SCL0 GPIO76
CON1-P07 PWM-003 GPIO206
CON1-P08 UTXD1 GPIO80
CON1-P10 URXD0 GPIO81
CON1-P11 URXD1 GPIO80
CON1-P12 I2S0\_BCK GPIO74
CON1-P13 UTXD0 GPIO79
CON1-P15 PWM-002 GPIO205
CON1-P16 URTS1 GPIO25
CON1-P18 UCTS1 GPIO24
CON1-P19 SPI0\_MO GPIO56
CON1-P21 SPI0\_MI GPIO55
CON1-P22 PCM\_CLK GPIO18
CON1-P23 SPI0\_CK GPIO54
CON1-P24 SPI0\_CSN GPIO53
CON1-P26 PCM\_RX GPIO20
CON1-P27 I2C\_SDA1 GPIO57
CON1-P28 I2C\_SCL1 GPIO58
CON1-P29 PCM\_RST GPIO22
CON1-P31 SPDIF\_OUT GPIO200
CON1-P32 PCM\_TX GPIO21
CON1-P33 I2S0\_MCLK GPIO126
CON1-P35 I2S0\_LRCK GPIO73
CON1-P36 PCM\_SYNC GPIO19
CON1-P37 SPDIF\_IN1 GPIO202
MIPI DSI of Banana pi BPI-R2
CN6-P01 VCC-3V3
CN6-P02 VCC-5V
CN6-P03 VCC-3V3
CN6-P04 VCC-5V
CN6-P05 GND
CN6-P06 VCC-5V
CN6-P07 GND
CN6-P08 VCC-5V
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 DSI\_TE GPIO84
CN6-P16 GND
CN6-P17 I2C\_SDA2 GPIO77
CN6-P18 DSI-D1N
CN6-P19 I2C\_SCL2 GPIO78
CN6-P20 DSI-D1P
CN6-P21 CTP-INT GPIO23
CN6-P22 GND
CN6-P23 CTP-RST GPIO236
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 GPIO28
CN6-P28 GND
CN6-P29 GPIO83
CN6-P30 DSI-D2N
CN6-P31 GPIO204
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCM\_BLPWM GPIO203
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
CON2 P03 UTXD2
CON2P02 URXD2
CON2P01 GND
MTK 7623N datasheet for development board programming guide v1.1 new update
CE,FCC,RoHS
Release
Android 6.0
Ubuntu with kernel 4.4
Ubuntu with kernel 4.14
OpenWrt(LEDE)
  • Banana Pi BPI-R2 19.07.7 OpenWRT Router image Kernel 4.14.112 2021-04-15
Wan IP : DHCP
Lan IP :192.168.1.1
google image download link:https://drive.google.com/file/d/1OFSq6-23CT31Nt5Nohq2E9Nh6RmsCGXC/view?usp=sharing
baidu link : https://pan.baidu.com/s/1_0dWUsLXc4HUurAdleOf_w pincode: 7262
Discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-r2-19-07-7-openwrt-router-image-2021-04-15/12161
Source code https://github.com/BPI-SINOVOIP/BPI-R2-OPENWRT-19.07.7.git
  • Banana Pi BPI-R2 OPENWRT 19.07 Image:
http://forum.banana-pi.org/t/banana-pi-bpi-r2-openwrt-19-07-image/11323
  • Official OpenWR 18.06.4 for Banana Pi BPI-R2 image released 2019-7-04
image download:https://downloads.openwrt.org/releases/18.06.4/targets/mediatek/mt7623/
https://openwrt.org/toh/sinovoip/sinovoip_banana_pi_r2
Forum pthread:http://forum.banana-pi.org/t/official-openwr-18-06-4-for-banana-pi-bpi-r2-image-released-2019-7-04/9459
  • BananaPI BPI-R2 Openwrt18.06 Image Release and source code 2019-03-06
source code on Github: https://github.com/BPI-SINOVOIP/BPI-R2-OPENWRT-18.06
image download: https://dev.banana-pi.org.cn/Image/BPI-R2/Openwrt/1806/
MD5SUM
mtk-bpi-r2-EMMC.img : 5d1537c45679de352dd25d8dda46b9ad
mtk-bpi-r2-SD.img :71fce303abdceed4f1c3548d5a3fc207
forum Pthread: http://forum.banana-pi.org/t/bananapi-bpi-r2-openwrt18-06-demo-image-release-2019-03-06/8562
OpenMPTCProuter
  • Armbian preview image for Bananapi R2 / K4.19.y
https://www.armbian.com/bananapi-r2/
Centos 7
how to install: https://www.electromaker.io/tutorial/blog/getting-started-with-centos-on-the-banana-pi-r2-how-to-install-centos-on-banana-pi-r2
  • 2019-8-12 update.[BPI-R2] debian 10 buster image with Kernel 4.19.62, shared by frank-w
Kernel: 4.19.62,uboot 2019-07 with erase-env + sata-support,new preloader (2019-07-22),configured to ip 192.168.0.11 on lan0,openssh-server running with root-login (should be disabled afterwards),username/password: root/bananapi
google drive:https://drive.google.com/open?id=1oP7jy1KrrIOifvImo2nQ59wx3_9hHkgk
how to : https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:storage#short_install-guide
forum discuss:http://forum.banana-pi.org/t/bpi-r2-debian-buster-image-with-kernel-4-19-62/9601
  • Image Release
  • Image Release
release date :2018-06-17
  • SD-Card images:
  • Discuss on forum :
yocto Linux
MQLinux 19.02 beta
Main features:
Highly streamlined embedded design system, running in memory
Mutilple Language (en/zh_CN currently)
DNS Proxy/Cache
DDNS
VLAN Extension for WAN
Multiple WAN (each ethernet port can be defined)
DHCP Server
FTP Server
PPPoE Server
Samber Server
VPN client/Server (PPTP VPN, IPsecVPN, OpenVPN)
Cloud Login
Firewall
IP-MAC Locking
Port Mapping/DMZ/UPnP
Diagnose Tools …
image dwonload: https://drive.google.com/file/d/1Ws2IUiCGSKKQ2dCM5XJBV-pog-hk17PM/view?usp=sharing
MD5: 09b58f050166ed5d09803e1de56d7890
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-r2-new-image-mqlinux-19-02-beta/8832
FreeBSD
  • BPI-R2 FreeBSD support/ZRouter.org support
http://forum.banana-pi.org/t/bpi-r2-freebsd-support-zrouter-org-support/7290
Project on BPI-R2
official aliexpress shop
