Banana Pi BPI-W2
  • Mali T820 MP3 GPU
  • 2G DDR4 SDRAM
  • 2 SATA interface
  • 1XGigabit LAN 1x Gigabit WAN
  • HDMI in & HDMI out
  • Mini DP
BPI-W2 hardware spec
Specification of Banana pi BPI-R2 |
Realtek RTD1296 quad-core ARM A53 |
Mali T820 MP3 GPU |
2GB DDR4 \(shared with GPU\) |
12V @ 2A via DC power | | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | 2x 10/100/1000Mbps Ethernet | **Option** ,not support onboard WIFI & BT | 1 RGMII interface with PIN | MicroSD \(TF\) card, 2 SATA 6Gbps ,eMMC,SIM card slot | HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP | The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. | Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in | 1\* HDMI out port and 1\* HDMI In port | HDMI, I2S audio,Audio micro out, Audio out/in with PIN define | 1 pcie 2.0 interface | 1 pcie 1.1 and SDIO interface | 1x USB 3.0 host | 2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN | 1\* M.2 interface | 1\* Mini DP | 1 type C interface | RTC battery power interface | Reset button, Power button, U-boot button | Red, Green, Blue | IR reciever | 148 mm × 100.5mm | 100g |
