Getting Started with M2P
Overview: Banana Pi BPI-M2+
Overview: BPI-M2+ Ubuntu linux
Overview:BPI-M2+ Debian linux
Overview:BPI-M2+ Rasbian linux
BPI-M2+ H3
  • Quad-core 1.2GHz Cortex-A7 H3
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
Development For Android
Load your first image on M2P
 Ex: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-image-android7-0-release-2018-6-30/6147
 * Here is the example of M3
Load your image on M2P EMMC
 1.The only different with sd card burning is the image burning mode item choice
 2.After succeed to burn image to SD, then plug SD card in your M2P
 3.Press power button, device will copy image to EMMC automatically
Development For Linux
 * Using your USB-Serial Connect debug console on M2P
 * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
 5.Login user/password: pi/bananapi or root/bananapi.
Load your first image on M2P EMMC
 * Run your M2P with TF card
 * Plug your USB disk in M2P
 * After M2P recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M2P, take TF card out, power on M2P with EMMC
Update your image
  * execute “bpi-tools”, to update your bpi tools;
  * execute “bpi-update -c bpi-m2p.conf”, to download new driver to update your image
  * execute “file *.tgz”, to check download files’ type is compressed data
  * execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/bpi-m2p/BPI_M2P_720P.img.gz”
  * execute “bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m2p/BPI_M2P_720P.img.gz”, to update your bootloader
  * reboot
How to build uboot & kernel
Install tools
Clone code
How to create an image
  • Boot your SD card with M2P, after M2P finish starting, copy your files and config your system, then poweroff M2P. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2p.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
  • To access a GPIO pin you first need to export it with
  • with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)
 (position of letter in alphabet - 1) * 32 + pin number
  for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter)
  • echo "out/in" > /sys/class/gpio/gpio*NUMBER*/direction
  • echo "0/1" > /sys/class/gpio/gpio*NUMBER*/value
OTG
1. On M2P console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2P and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2P OTG
  • If yes, we could execute "adb shell" to connect M2P by adb now
  • Use iperf3 to test gmac
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2P
Driver code:
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
1.Download M2P bsp code
  • After you cloned project, execute command “cd BPI-M2P-bsp”
2.Change to your boot logo
  • Prepare a ".bmp" picture, here I rotate 180°, as follows :
  • Change your picture name as "bootlogo.bmp"
  • put your picture to "sunxi-pack/chips/sun8iw7p1/configs/BPI-M2P-xxxP/"
3.Build your code
  • "./build.sh BPI-M2P-720P"
  • choose 1
  • After you built the project, you will see “SD” directory
4.Install a raspbian image on your SD card
5.Plug your SD card into your Ubuntu PC
(1) check your SD card was recognised as /dev/sdxx, as you can see, mine sd card was recognised as /dev/sde
6.Then “cd SD/bpi-m2p/100MB”
7.Execute command “bpi-bootsel BPI-M2P-720P.img.gz /dev/sde”
8.Insert your updated SD card to board, and power on, you will see:
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to M2P
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
Reference Link
