Banana Pi Series Comparison
Banana Pi Single board computer Comparison | ||||||||||
module | BPI-M1 | BPI-M1+ | BPI-M2+ | BPI-M2 Zero | BPI-M2 Magic | BPI-M2 Berry | BPI-M2 Ulra | BPI-M3 | BPI-M64 | |
photo | ||||||||||
CPU | A20,32 Bit Cortex™-A7 Dual-Core | A20,32 Bit Cortex™-A7 Dual-Core | H3,32 Bit Cortex™-A7 Quad-Core | H2+,32 Bit Cortex™-A7 Quad-Core | A33/R16,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | R40/V40,32 Bit Cortex™-A7 Quad-Core | A83T,32 Bit Cortex™-A7 Octa-Core | A64, 64 Bit Cortex A53 Quad Core | |
GPU | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | ARM® Mali400MP2 | PowerVR SGX544MP2 GPU | ARM® Mali400MP2 | |
Memory \(SDRAM\) | 1G (shared with GPU) | 1G (shared with GPU) | 1G (shared with GPU) | 512M(shared with GPU) | 512(shared with GPU) | 1G (shared with GPU) | 2G (shared with GPU) | 2G (shared with GPU) | 2G (shared with GPU) | |
Onboard Storage | SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC | SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC | MicroSD(TF) card /MMC card slot eMMC 8GB | MicroSD(TF) card /MMC card slot | MicroSD(TF) card /MMC card slot eMMC 8GB(option) | MicroSD (TF) card / MMC card slot eMMC 8GB SATA 2.0 port via USB | MicroSD (TF) card / MMC card slot eMMC 8GB | MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC | MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB | |
Network | 10/100/1000 Ethernet | 10/100/1000 Ethernet | 10/100/1000 Ethernet | NOPE | NOPE | 10/100/1000 Ethernet | 10/100/1000 Ethernet | 10/100/1000 Ethernet | 10/100/1000 Ethernet | |
Onboard WIFI &BT | NOPE | 802.11b/g/n | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | 802.11b/g/n & BT4.0 | |
Display | HDMI, CVBS , LVDS/RGB | HDMI, CVBS , LVDS/RGB | HDMI | mini HDMI | MIPI/LVDS | HDMI, MIPI | HDMI, MIPI | HDMI, MIPI | HDMI, MIPI | |
Camera | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface | Parallel 8-bit camera interface MIPI Camera serial Interface(CSI) | Parallel 8-bit camera interface | |
Video Outputs | HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps | HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps | Support H.265 decode by 4K@30fps, HDMI 1.4 1080p@60fps
Support H.264 video encoding up to 1080p@30fps ||HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps || Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps|| |
