Banana Pi BPI-P2 Pro
Banana Pi BPI-P2 Pro is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Arm Cortex-A35 Rockchip RK3308 processor, with 2G RAM memory.8G eMMC flash,100M LAN,add PoE function support ,Wifi & Bluetooth onboard, It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
- CPU:Quad-core Arm Cortex-A35 Rockchip RK3308.
- 2G LPDDR2 SDRAM.
- 8G eMMC flash onboard.
- WiFi (AP6255) & Bluetooth onboard.
- 100M LAN
- How to development : Getting Start with BPI-P2 Pro
HardWare Specification of Banana pi BPI-P2 Zero VS BPI-M2 zero VS Raspberry Pi Zero W | ||||
Module | Banana Pi BPI-P2 Pro | Banana Pi BPI-P2 Zero | Banana Pi BPI-M2 ZERO | Raspberry Pi Zero W |
CPU | Quad-core Arm Cortex-A35 Rockchip RK3308 | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Allwinner H3/H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
GPU | NOPE | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | VideoCore IV |
Memory \(SDRAM\) | 2G | 512M DDR3(shared with GPU) | 512M DDR3(shared with GPU) | 512 MB DDR2 |
Onboard Storage | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) |
Onboard Network | 100M LAN | 100M LAN | NOPE (but can extension with PIN define) | NOPE |
PoE power | PoE function support | PoE function support | NOPE | NOPE |
Onboard flash | 8G eMMC | 8G eMMC | NOPE | NOPE |
Onboard WIFI | SDIO AP6255 | SDIO AP6212(option AP6181、AP6335) | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 |
Video decoding | 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 | 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 | 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder | |
Video input | A CSI input connector Camera | A CSI input connector Camera | CSI camera connector | |
Video Outputs | mini HDMI 1.4,1080P@30fps, DHCP | mini HDMI 1.4,1080P@30fps, DHCP | Mini HDMI and USB On-The-Go ports | |
Audio Output | Mic | Mini HDMI | Mini HDMI | Mini HDMI |
Power Source | TYPE C 5V/2A | Micro USB with 5V/2A or PoE power | Micro USB with 5V/2A | 5V/2A |
USB 2.0 Ports | one USB 2.0 OTG | one USB 2.0 OTG | one USB 2.0 OTG | one USB 2.0 OTG |
Buttons | Recovery ,Reset | Power Button, Reset Button | Power Button, Reset Button | Composite video and reset headers |
Low-level peripherals | 40 Pin + 12 Pin | 40 Pins Header,compatible with Raspberry Pi 3 | 40 Pins Header,compatible with Raspberry Pi 3 | 40 PIN |
uart GPIO\(1x3\) pin | UART, ground | UART, ground | UART, ground | UART |
LED | Power led & Status led | Power led & Status led | Power led & Status led | Power Status LED |
IR | N/A | N/A | N/A | N/A |
Supported OS | linux | android linux | android linx | Linux |
Product size | 65mm X 52.5mm | 65mm X 52.5mm | 65mm × 30mm | 65mm x 30mm |
Weight | 30g | 30g | 15g | 9g |
PoE support
