香蕉派 BPI-M2 ZERO
产品介绍
- 512MB DDR 3 SDRAM.
- Mini HDMI.
快速上手
- 如何在BPI-M2 Zero上进行开发: 快速上手 香蕉派 BPI-M2 Zero
硬件接口
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 |
| IR | N/A | N/A | N/A |
| Weight | 30g | 15g | 9g |
| 40 PIN GPIO of Banana pi BPI-M2 zero | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
| 24 PIN CSI Camera connector of Banana pi BPI-M2 Zero | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| jumper CON3 of Banana pi BPI-M2 Zero | |||
| CON3 P01 | GND | ||
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
- Allwinner documents:
- Android 4.4 source code
- Linux source code
- Banana Pi BPI-M2 Zero new image: 2020-04-28 Debian Rasbian Ubuntu
- 2020-04-28-debian-9-stretch-lite-bpi-m2z-sd-emmc.img.zip
- 2020-04-28-raspbian-stretch-bpi-m2z-sd-emmc.img.zip
- 2020-04-28-ubuntu-16.04-mate-desktop-bpi-m2z-sd-emmc.img.zip
- 2020-04-28-ubuntu-16.04-server-bpi-m2z-sd-emmc.img.zip
Android 4.4
2018-07-09 update Android 4.4
2017-11-12 update Android 4.4
- Forum pthread:
- Image Link:
- Forum thread:
RetroPie
retrorangepi
Raspbian
raspbian-jessie-ap6212-bpi-m2z-sd-emmc image
- raspbian-jessie-ap6212-bpi-m2z-sd-emmc image 2020-04-10,fixed wifi&bt issue
- google driver https://drive.google.com/file/d/1Xk86WchdJemKb4ltCX0AB9wRj5NJcZL1/view
- baidu cloud: https://pan.baidu.com/s/1eKs85jMW3PS8pdX4jukLUQ PIN code:6W2M
- discuss on fourm: http://forum.banana-pi.org/t/banana-pi-bpi-m2-zero-new-image-2020-04-10-raspbian-jessie-ap6212-bpi-m2z-sd-emmc-image/10978
M2Z & P2Zero Raspbian 9.4
- Features Map http://wiki.banana-pi.org/M2Z_Image_Map#Raspbian_9.4
- HDMI-Version
- Google Drive : https://drive.google.com/open?id=14tsP-ctECFxFBsF7Lmuv_C-Bm7Xppl79
- Baidu Drive : https://pan.baidu.com/s/1gmg-qX235t5kpL1N9uHy5A ( PinCode: 146j )
- Md5sum : 25aca018ee40a6df903e1f51b9d73327
- HDMI-Version
2018-07-09
- Image Link:
- Google Drive: https://drive.google.com/file/d/1XMVCWCWoWmhzL-c89rkqzZVE_k7xYCvd/view
- baidu Drive: https://pan.baidu.com/s/1ahXv3Hl7Dst7uBwz60pcrg 2
- Forum thread:
Ubuntu 16.04 mate desktop
2018-07-09
- Image Link:
- Forum thread:
2017-11-13
- Image Link:
- Forum thread:
