Getting Started with CM4
Revision as of 08:28, 13 January 2023 by Dangku (talk | contribs) (→Android)
Banana Pi BPI-CM4
2. Short the usb boot test point on the main board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, the board will enter usb download mode and be identified correctly by PC.
File:Cm4 usb download.png
Android DTB overlay
Bananapi CM4 DTBO idx value table, default idx value is 0 in release image.
2 i2c1 enable i2c 1
3 i2c2 enable i2c 2
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m2s:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
Switch Mipi Panel
Panel Rotation
   index 1f51703..d592a44 100644
    else
        ro.sf.lcd_density=213 \
    endif
   index 4a698b0..3d41b63 100755
   @@ -876,8 +876,8 @@
                   reg = <0x5d>;
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
 $ apt-get install pv
Install Image to SDcard
 $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
3. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
 $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/sdX
Install Image to EMMC
 $ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
4. Install with bpi-tools command
 $ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/mmcblk0
Build Linux Source Code
2. Build the bsp source code
 hifi_pcm5122.dtbo  pdmmic.dtbo        sdio.dtbo                 waveshare_tft24_lcd.dtbo
 i2c1.dtbo          pwm_c-beeper.dtbo    spi0.dtbo                 waveshare_tft35c_lcd.dtbo
 i2c2.dtbo          pwm_cd-c.dtbo           spi0_flash.dtbo        wifi_bt_rtl8822cs.dtbo
 i2s.dtbo            pwm_cd.dtbo              uart1_cts_rts.dtbo    i2smic.dtbo    pwm_ef.dtbo
 uart1.dtbo        os08a10.dtbo              pwm_ef-f.dtbo          uart2.dtbo
 # Device Tree Overlays
 overlays="i2c2 spi0 uart1"
Enable Camera
The linux release image is camera disabled default, according to the following configuration, it can be enabled by yourself.
 overlays="os08a10"
 iv009_isp_iq
 iv009_isp_lens
 iv009_isp_sensor
 iv009_isp
 #choose isp register sequence
Switch Mipi Panel
 # Mipi panel type
 #    Symbol    | Resolution
 panel_type=lcd_0
Panel Rotation
 Section "Device"
     # Rotate off
 #   Option "Rotate" "off"
     Option "Rotate" "CW"
 #   Option "Rotate" "UD"
 #   Option "Rotate" "CCW"
 EndSection
 Section "InputClass"
     MatchIsTouchscreen "on"
     MatchProduct "goodix-ts"
     MatchDriver "libinput"
 EndSection
1. Sysfs dynamically change.
2. Boot Configuration change.
 # Framebuffer Rotate
 # 0 - origin 0 degree
 # 1 - 90 degree
 # 2 - 180 degree
 # 3 - 270 degree
 fb_rotate=0
Note: This WiringPi only support set 26pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, ..., you must enable dtb overlay in boot.ini
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
lcd1602-pi, BPI LCD 1602 display module example.
Build and install
 $ cd RPi.GPIO-Amlogic
WiringPi2-Python
Build and install
 $ sudo apt-get Install python python-dev python-setuptools swig git
 $ cd WiringPi2-Python-Amlogic
EC20 LTE 4G Module
1. AT test
After the module is connected and Linux OS bootup. several ttyUSB* device files are created in the directory /dev. For EC20, /dev/ttyUSB2 is the AT port.
2. Connect Network via qmi_wwan on Ubuntu Desktop
Click edit connections in network manager menu
Add a new mobile broadband connection
Choose qmi channel device
When the qmi_wwan_q driver has been installed in the module, a network device and a QMI channel are created. The network device is named as wwanX and the QMI channel is /dev/cdc-wdmX. The network device is used for data transmission, and QMI channel is used for QMI message interaction
Choose carrier provider's country region
Choose carrier provider.
Set connection name, carrier connection username/password and APN if needed.
Setup finished, now you can connect it.
3. Connect Network via pppd on Ubuntu&Debian Server
Install pppd
 $ sudo apt install ipppd
Change AT device, username and password to your local carrier in /etc/ppp/peers/quectel-ppp
Change APN to your local carrier in /etc/ppp/peers/quectel-chat-connect
Two ways command to start pppd, you can check the process of PPP calling setup log here.
 # pppd call quectel-ppp &
or
Terminate pppd process:
 # quectel-ppp-kill
4. Connect Network via qmi_wwan on Ubuntu&Debian Server
[quectel-CM] is a connection manager program for you to set up data connection manually. You can check the process of qmi_wwan calling setup log here.
 # quectel-CM &
Terminate quectel-CM process:
 # killall quectel-CM
Boot Linux from SSD
A311d soc rom and BPI-M2S-bsp uboot are both not support nvme boot, so the only way for booting linux from SSD is create a bootable sdcard or emmc with bootloader and boot partition flashed, then load rootfs from SSD. After bootup, everything will run from SSD. You need a minipcie to nvme adapter board because bananapi cm4io has a minipcie slot onboard.
1. The simple way is flash the CM4 Linux image to sdcard or emmc for bootable and also flash it to the nvme ssd for loading rootfs.
2. Bootup the CM4 board with sdcard or emmc, modify /boot/boot.ini to load rootfs from nvme partition for kernel.
 diff a/boot/boot.ini b/boot/boot.ini
 index 2222e79..c485067 100755
 --- a/boot/boot.ini
 +++ b/boot/boot.ini
 @@ -20,6 +20,8 @@ fi;
  # Load env.txt
3. Reboot the system, kernel will load rootfs from nvme ssd.
4. Test performance
You can verify the performance of your SSD on Pi Benchmarks using the following command:
Test results for sd, emmc and nvme ssd (Samsung 970EVOPlus)
Category Test Sdcard Test Result Emmc Test Result Nvme SSD Test Result
HDParm Disk Read 60.67 MB/s 148.80 MB/s 351.29 MB/s
HDParm Cached Disk Read 56.71 MB/s 141.02 MB/s 347.03 MB/s
DD Disk Write 14 MB/s 51.0 MB/s 244 MB/s
FIO 4k random read 2176 IOPS (8704 KB/s) 8438 IOPS (33753 KB/s) 101386 IOPS (405544 KB/s)
FIO 4k random write 932 IOPS (3729 KB/s) 10876 IOPS (43505 KB/s) 43206 IOPS (172827 KB/s)
IOZone 4k read 8586 KB/s 20311 KB/s 119475 KB/s
IOZone 4k write 2385 KB/s 19016 KB/s 90619 KB/s
IOZone 4k random read 6734 KB/s 20807 KB/s 51517 KB/s
IOZone 4k random write 3737 KB/s 22731 KB/s 95139 KB/s
Score: 1076 Score: 5446 Score: 24550
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m2s_v1#reset
   resetting ...
   BPI: try boot from sdcard
   reading boot.ini
   Starting boot.ini...
   reading env.txt
   HDMI: Autodetect: 1080p60hz
   reading Image.gz
   reading bananapi_m2s.dtb
   reading uInitrd
 $ sync
Cloud-init&Snap
or
 $ sudo apt purge cloud-init
2. disable or remove snap
 $ sudo apt purge snapd
Enable rc-local
 [Unit]
 After=network.target
 [Service]
 Type=forking
 ExecStart=/etc/rc.local start
 TimeoutSec=0
 RemainAfterExit=yes
 GuessMainPID=no
 [Install]
 WantedBy=multi-user.target
 Alias=rc-local.service
Create /etc/rc.local file.
 sudo nano /etc/rc.local
 #!/bin/sh
 # rc.local
 # value on error.
 # bits.
 exit 0
 $ sudo chmod +x /etc/rc.local
 $ sudo reboot
Enable sudo for Debian
 $ su -
 Password:(enter bananapi)
 # apt install sudo
 # adduser pi sudo
Install Docker Engine
1. Set up the repository
 $ sudo apt-get update
Set up the stable repository
 $  echo \
2. Install Docker Engine
 $ sudo docker run hello-world
