BPI-Bit-S2
Revision as of 18:22, 5 December 2022 by Wind (talk | contribs) (Key features)
About BPI-Bit-S2
BPI-Bit-S2 with ESP32-S2
BPI-Bit with ESP32
BPI-Leaf-S3 with ESP32-S3
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
BPI-Bit-S2 development board is a successor to BPI:Bit, inheriting most of the core hardware functions.
Key features
  • ESP32-S2
  • 5x5 RGB LED matrix
  • 1 buzzer
  • 1 thermistor sensor
  • 2 photosensitive sensors
  • 2 Programmable keys,1 BOOT key,1 Reset key
  • Type-C USB interface
  • Size 5x5cm
  • The Goldfinger Edge Connector definition is fully compatible with Micro: Bit
Hardware upgrade and function comparison
BPI:Bit VS BPI-Bit-S2
Module BPI:Bit BPI-Bit-S2
MCU ESP32 ESP32-S2
ROM 448 KB 128 KB
RAM 520 KB 320 KB
FlASH ROM 4096 KB 4096 KB
PSRAM None 2048 KB
Wireless Capability WIFI,Bluetooth WIFI
LED 25 WS2812-5050 RGB LED 25 WS2812-3535 RGB LED
Key 2 programmable keys,1 RST key 2 programmable keys,1 BOOT key,1 RST key
Buzzer 5.3x5.3mm buzzer 8.5x8.5mm buzzer
USB interface Micro USB Type-C USB
USB to TTL support None
Battery socket support None
IO 19 pin Goldfinger IO 19 pin Goldfinger IO
Nine-axis sensor support None
Photosensitive sensor 2 2
Thermistor sensor 1 1
BPI-Bit-S2 specification
MCU ESP32-S2FN4R2,Xtensa® 32 bit LX7 Single-Core Processer
Frequency 240MHz MAX
operating temperature -40℃~+85℃
ROM 128 KB
SRAM 320 KB
FLASH ROM 4 MB
PSRAM 2 MB
WIFI IEEE 802.11 b/g/n ,2.4Ghz
GPIO 19 available GPIO pins have been introduced
Peripheral functions ADC,TOUCH,PWM,SPI,I2C,I2S,Pulse counter, RMT,TWAI® Controller,SD/MMC,LCD_CAMERA
External crystal 40Mhz
Buzzer 8.5x8.5mm buzzer
LED 25 WS2812 rgb LED, single line GPIO control; 1 monochrome LED, controlled by GPIO0
Photosensitive sensor 2 photosensitive sensor
Thermistor sensor 1 thermistor sensor
IO 19 pins Goldfinger IO,19 pins contacts on the back
Key 2 Programmable keys,1 BOOT key,1 Reset key
USB USB Type-C interface,full speed USB OTG,USB-ACM
Operating voltage 3.3V
Power USB Type-C input 5V,or Goldfinger IO input 3.3V power supply
Size 5 * 5 cm
On-board peripherals
Peripheral GPIO allocation and signal type
Photosensitive sensor(L) GPIO 12 Analog Input
Photosensitive sensor(R) GPIO 13 Analog Input
Thermistor sensor GPIO 14 Analog Input
Key A GPIO 38 Digital Input
Key B GPIO 33 Digital Input
Key BOOT GPIO 0 Digital Input
Buzzer GPIO 17 PWM(Digital Output)
RGB LEDs GPIO 18 Digital Output
5*5 RGB LED
BPI-Bit-S2 have 25 WS2812 full color RGB LED, single GPIO ontrol.The three primary color pixels of each LED can achieve 8bit 256 level brightness display, and achieve 16777216 color full color display, scanning frequency is not less than 400Hz/s.
5*5 LEDs list of BPI-Bit-S2
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
Goldfinger GPIO define
SPI,I2C
Function Pin Name GPIO Num
SPI_SCK P13 GPIO36
SPI_MISO P14 GPIO37
SPI_MOSI P15 GPIO35
SPI_CS P16 GPIO34
I2C_SCL P19 GPIO16
I2C_SDA P20 GPIO15
Power
Webduino
webduino在线积木编程平台
webduino积木编程平台 Windows安装版
webduino在线教学手册
Arduino
Preparing...
MicroPython
Preparing...
BPI-Bit Lite schematic
