Getting Started with M5/M2Pro
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
- 1. Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
IR Remote Control Custom
- Android keycode.
- push remote.cfg back
- 3. Get the remote keycode
- custom_code = 0xfe01
- 5. Reboot the board
- 2. M5 and M2pro are compatiable with same Linux image.
- 4. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
Install Image to SDcard
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
- 3. Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/sdX
Install Image to EMMC
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
- 4. Install the linux image in udisk with bpi-tools command
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m5-xxx.img.zip /dev/mmcblk0
Build Linux Source Code
- 2. Update the overlays env in vfat /boot/firmware/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
- Build and install
WiringPi2-Python
- Build and install
$ sudo apt-get Install python python-dev python-setuptools swig wiringpi git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python setup.py install
Custom Linux Boot Logo
Custom Android Boot Logo
- 4. Extract this tool
Boot Sequence
bananapi_m5# mmc erase 0 1000
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
- Linux Wifi STA mode
network:
version: 2
renderer: networkd
wifis:
wlan0:
dhcp4: true
access-points:
"bananapi":
password: "123456789"
- Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 2.4GHz
channel: 6
auth:
key-management: psk
network:
version: 2
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 5GHz
channel: 36
auth:
key-management: psk
network:
version: 2
renderer: networkd
ethernets:
wlan0:
dhcp4: no
addresses:
- 192.168.11.1/24
- 2). Install hostapd
$ sudo apt install hostapd
option routers 192.168.11.1;
- 5). Start Service
- 6). Routing configuration.
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
$ su - Password:(enter bananapi) # apt install sudo # adduser pi sudo
Install Docker Engine
- 1. Set up the repository
$ echo \
- 2. Install Docker Engine
$ sudo docker run hello-world
