Banana Pi BPI-P2 Zero
Revision as of 01:32, 12 October 2022 by Sinovoip (talk | contribs) (Linux)
Overview BPI-P2 Zero with Allwinner H2+ chip
Overview BPI-P2 zero PoE support
Banana Pi BPI-M2 ZERO with Allwinner H2+ chip
Banana Pi BPI-P2 Zero with BPI-9600 POE module
BPI-P2 Zero Case
Banana Pi BPI-P2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • CPU: Allwinner H3/H2+, Quad-core Cortex-A7.
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
  • 100M LAN
  • 8G eMMC flash onboard.
IR N/A N/A N/A
Weight 30g 15g 9g
40 PIN GPIO of Banana pi BPI-P2 Zero
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
24 PIN CSI Camera connector of Banana pi BPI-P2 Zero
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
jumper CON3 of Banana pi BPI-P2 Zero
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
PoE support
  • Android 4.4 source code
forum pthread: http://forum.banana-pi.org/t/bpi-m2-android-4-4-source-code-download-link/3159
  • Linux source code
  • 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_jammy_edge_5.19.6_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/1vP_047mfuAhSjBkZvb3w-iTGktd_BZbu/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1uhbUMYeplPybxTn_Cybpvw?pwd=8888 (pincode: 8888)
Discuss on Forum:https://forum.banana-pi.org.cn/t/topic/3973
  • 2022-10-12 Armbian_22.11.0-trunk_Bananapip2zero_bullseye_edge_5.19.6_xfce_desktop.img
Google Drive:https://drive.google.com/file/d/1YSaM1ob80EPcNoeVKYPjtCeMItBlTMET/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1CrZQhN3BR6bx7uMTZYVeMQ?pwd=8888 (pincode: 8888)
Discuss on Forum:https://forum.banana-pi.org.cn/t/topic/3972
  • 2022-09-27-Armbian_22.11.0-trunk_jammy_edge_lubuntu_5.19.6-qt5-swap-bpi-P2z-M2Z-10804MB
Google Drive: https://drive.google.com/file/d/1_rsQthyCU4HaN8tcGsPMvzt6dMwaRI-A/view?usp=sharing
Baidu Cloud:https://pan.baidu.com/s/1RKJzzpMOHnFW0nj8I-NJIA?pwd=rk22 (pincode: rk22)
MD5:f4dfbe234c21a6038f50f699780d4e03
  • 2020-04-28 update, Debian 9, Rasbian Stretch, Ubuntu 16.04 Mate Desktop and Ubuntu 16.04 Server images, base on kernel 4.4,Images for m2z and p2z board are compatible.
  • 2019-4-30 update BPI-M2 Zero & BPI-P2 Zero Ubuntu Server 16.04
Image Links:
HDMI-Version
  • 2018-4-30 update BPI-M2 Zero & P2Zero Ubuntu Desktop 16.04
Image Links:
HDMI-Version
BPI-P2 Zero image Features Map : http://wiki.banana-pi.org/P2Z_Image_Map
Google Drive : https://drive.google.com/open?id=1izY4ib2roA4I9s4psbXqZq5sBXLkCgBE
Baidu Drive : https://pan.baidu.com/s/1-pAplB8_j_W5mUsYsinavg
Forum pthread : http://forum.banana-pi.org/t/bananapi-bpi-p2-zero-h2-with-poe-ubuntu-image-release-2018-08-17/6533
