Getting Started with M2 Ultra & Berry
Revision as of 06:03, 27 September 2022 by Czj (talk | contribs) (→Linux)
BPI-M2U
Overview Banana Pi BPI-M2U
Overview Banana Pi BPI-M2 Berry
Overview: BPI-M2U respbian linux
  • Quad Core ARM Cortex A7 CPU R40
  • 2GB DDR3 SDRAM
  • 8 GB eMMC storage
  • SATA Interface
BPI-M2 Berry
  Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
  • Quad Core ARM Cortex A7 CPU V40.
  • 1GB DDR3 SDRAM.
  • SATA Interface
 * Prepare 8G/above TF card, USB-Serial interface, PC with Windows System
 * Using your USB-Serial Connect debug console on M2P
 * Here is an example image link: http://forum.banana-pi.org/t/banana-pi-bpi-m2u-berry-new-image-release-raspbian-jessie-8-0-2018-5-24/5812
 2.Put the TF card into a TF-USB adapter and plug it to your PC USB interface.
 3.Download the flashing tools "BalenaEtcher" and start it.
 4.Click "Flash from file" to select your image file.(.img or .zip)
 5.Click "Select target" to choose your USB device.
 6.Start to flash and wait for burning completely.
Load your first image on M2U EMMC
 1.Bootup your M2U with Micro SD card
 2.Copy "xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to your USB disk
 3.Plug your USB disk in M2U
 4.Mount the USB disk and flash the image file to eMMC
 * bpi-tools
 curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools%7Csudo -E bash
 mount /dev/sda1 /mnt
 cd /mnt
 bpi-copy xxx-sd-emmc-xxx.img.zip /dev/mmcblk0
 * dd command
 cd /mnt
 unzip -p xxx-sd-emmc-xxx.img.zip |pv| dd of=/dev/mmcblk0 bs=10M status=noxfer
 5.Then power off M2U, take TF card out, power on M2U
How to build uboot & kernel
Install tools
Clone code
SATA
1. Mount SATA on M2U
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2U and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2U OTG
  • If yes, we could execute "adb shell" to connect M2U by adb now
LCD 5" & LCD 7"
  • Find "BPI_M2U_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m2u/BPI_M2U_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M2U console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2U
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to M2U
  • cd /usr/local/bin
WringPi
File System
Install Qt5.7 & Qtcreator
1.Prepare a 32Gb TF card
2.Use GParted to resize root point '/' as 32Gb
3.apt-get install libxcb*
4.download qt5.7
5.make & make install
6.apt-get install qtcreator
7.Config qtcreator
Reference Link
