Banana Pi BPI-R3
Application direction
- . Internet service Router
- . Wireless Router
- . Wireless Repeater
- . Home security Gateyway
- . Home Automation
- . Nas device
- . 2G DDR RAM
- . 8G eMMC flash
- . 2 SFP 2.5GbE
- . 5 GbE network port
- . POE support (optional)
- . Mini PCIe via USB
- . M.2 KEY-E PCIe inerface
- . Mciro SD card interfact
- . 26 PIN GPIO
Jumper setting
Jumper Setting of Banana pi BPI-R3 | ||||
Jumper Setting | SW1 | SW2 | SW5 | SW6 |
SPIM-NoR | Low | Low | Low | X |
SPIM-Nand | High | Low | High | X |
eMMC | Low | High | X | Low |
SD card | High | High | X | High |
HardWare Specification of Banana pi BPI-R3 | |||
CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design | ||
SDRAM | 2 GB LPDDR3 | ||
GPIO | 26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
On board Network | 5 Port 10/100/1000Mbps Ethernet | ||
SFP | 2 SFP 2.5GbE | ||
Wifi | Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) | ||
mini PCIE | Mini PCIe via USB | ||
M.2 interface | M.2 KEY-M PCIe inerface | ||
USB | 1 USB 3.0 host ,2 USB interface with slot. | ||
Buttons | Reset button,WPS botton, boot switch | ||
Sizes | 100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2 | ||
Weight | 200g |
Release image
- 2022-06-01udptae BPI-R3 OpenWRT 21.02 linux kerne 5.4, wifi 6E 2.4G and 5G working fine.support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware
- baidu link https://pan.baidu.com/s/1idqU1-bB4XD1LTGDAJxRGA?pwd=chez Pincode: chez
