BPI-PicoW-S3
Revision as of 07:41, 22 September 2022 by Czj (talk | contribs) (Espressif ESP32-S3)
BPI-PicoW-S3 with ESP32-S3
BPI-Leaf-S3 with ESP32-S3
BPI-Smart with ESP8266
BPI-Bit with ESP32
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
The Banana Pi BPI-PicoW-S3 is a series of low-powered microcontrollers designed for IoT development and Maker DIY board.same size as Raspberry Pi Pico board,It supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, the peripheral is compatible with low-power hardware design, and the power consumption is only 10uA in deep sleep mode.In terms of programming, the PicoW-S3 supports ESP-IDF, Arduino, micropython and other methods.
key features
  • ESP32-S3, Xtensa® 32 bit LX7
  • External PSRAM, FLASH
  • Ultra-low power 10uA
  • 2.4G WIFI, Bluetooth 5, Bluetooth mesh
  • GPIO, ADC, TOUCH, PWM, I2C, SPI, RMT, I2S, UART, LCD, CAMERA, USB, JTAG
  • 1*microUSB
  • 1*Full color LED
BPI-PicoW-S3 VS Rraspberry Pi PicoW, BPI-Leaf-S3, ESP32-S3-DevKitC-1
Development board BPI-PicoW-S3 Rraspberry Pi PicoW BPI-Leaf-S3 ESP32-S3-DevKitC-1
GPIO pinout 27 27 36 36
3.3v pin 1 1 2 2
5v pin 2 2 1 1
GND pin 8 8 4 4
Full color LED 1 on GPIO48 None 1 on GPIO48 1 on GPIO48
Chip directly connected to USB MicroUSB port x1 MicroUSB port x1 Type-C USB port x1 MicroUSB port x1
UART TTL to USB None None None CP2102-MicroUSB interface x1
External battery socket None None 3.7v lithium battery power supply interface None
Battery charging None None 500mA charging None
I²C 4pin connector None None 1 None
Espressif ESP32-S3
Esp32-S3 is an MCU chip that integrates 2.4 GHz Wi-Fi and Bluetooth 5 (LE) and supports Long Range mode. The ESP32-S3 runs on an Xtensa® 32-bit LX7 dual-core processor with a high frequency of 240 MHz, 512 KB built-in SRAM (TCM), 45 programmable GPIO pins, and a rich communication interface. Esp32-s3 supports larger capacity of high-speed Octal SPI flash and off-chip RAM, and supports user-configured data caching and instruction caching.
  • AI Acceleration Support: ESP32-S3 has additional support for vector instructions in the MCU, which provides acceleration for neural network computing and signal processing workloads. The software libraries for the above-mentioned optimized functions will become available very soon, in the form of updates to ESP-DSP and ESP-NN.
  • Rich IO interfaces: ESP32-S3 has 45 programmable GPIOs and common peripheral interfaces such as SPI, I2S, I2C, PWM, RMT, ADC, UART, SD/MMC host controller and TWAITM controller. Fourteen of the GPIOs can be configured as capacitive touch inputs for HMI interaction. In addition, ESP32-S3 is equipped with an ultra-low power coprocessor (ULP) and supports multiple low-power modes, making it widely applicable to various low-power application scenarios.
  • Security mechanism: ESP32-S3 provides comprehensive security mechanism and protection measures for iot devices to prevent all kinds of malicious attacks and threats. It supports Flash encryption based on AES-XTS algorithm, secure startup based on RSA algorithm, digital signature and HMAC. Esp32-s3 also includes a new "World Controller" module, which provides two non-interfering execution environments to implement a trusted execution environment or permission separation mechanism.
BPI-PicoW-S3 Spec Sheet
SoC ESP32-S3, Xtensa® 32-bit LX7 dual core
Basic frequency 240MHz MAX
Operating temperature -40℃~+85℃
On-chip ROM 384KB
On-chip SRAM 320KB
Onboard FLASH ROM 2MB
On-chip peripheral PSRAM 8MB
WIFI IEEE 802.11 b/g/n, 2.4Ghz band, 150Mbps
Bluetooth Bluetooth 5, Bluetooth mesh
GPIO BPI-PicoW-S3 has led out 27 available GPIOs
ADC 2 × 12-bit SAR ADC supporting 18 analog channel inputs
TOUCH Capacitive Touch Sensor 14
SPI 4
I2C 2. Support master or slave mode
I2S 2, input and output of serial stereo data
LCD 1, support 8-bit ~16-bit parallel RGB, I8080, MOTO6800 interface
CAMERA 1, supports 8-bit ~16-bit DVP image sensor interface
UART 3, supports asynchronous communication (RS232 and RS485) and IrDA
PWM 8 independent channels, 14-bit precision
MCPWM 2
USB 1 × Full Speed ​​USB 2.0 OTG, MicroUSB Female
USB Serial/JTAG Controller 1, USB full speed standard, CDC-ACM, JTAG
Temperature sensor 1, the measurement range is –20 °C to 110 °C, for monitoring the internal temperature of the chip
SD/MMC 1 × SDIO host interface, with 2 card slots, supports SD card 3.0 and 3.01, SDIO 3.0, CE-ATA 1.1, MMC 4.41, eMMC 4.5 and 4.51
TWAI® Controller 1, compatible with ISO11898-1 (CAN specification 2.0)
Generic DMA Controller 5 receive channels and 5 transmit channels
RMT 4-channel transmit, 4-channel receive, shared 384 x 32-bit RAM
Pulse Counter 4 pulse count controllers (units), each unit has 2 independent channels
Timer 4 × 54-bit general-purpose timers, 16-bit clock prescaler, 1 × 52-bit system timer, 3 × watchdog timers
External crystal 40Mhz
RTC and Low Power Management Power Management Unit (PMU) + Ultra Low Power Coprocessor (ULP)
Low power consumption current 10uA
Working Voltage 3.3V
Input voltage 3.3V~5.5V
Controllable full color LED 1
Size
BPI-PicoW-S3 size chart
Pin spacing 2.54mm
Hole Spacing 11.4mm/ 47mm
Hole size Inner diameter 2.1mm/Outer diameter 3.4mm
Mainboard size 21 × 51.88(mm)/0.83 x 2.04(inches)
Thickness 1.2mm
The pin spacing is compatible with universal boards (hole boards, dot matrix boards) and breadboards, which is convenient for debugging applications.
GPIO define
BPI-PicoW-S3 peripheral GPIO pin assignment
Peripheral Interface Signal Pins
ADC ADC1_CH0~9 GPIO 1~10
ADC2_CH0~9 GPIO 11~20
Touch Sensor TOUCH1~14 GPIO 1~14
JTAG MTCK GPIO 39
MTDO GPIO 40
MTDI GPIO 41
MTMS GPIO 42
UART Default assigned pins, can be redefined as any GPIO
U0RXD_in GPIO 44
U0CTS_in GPIO 16
U0DSR_in Any GPIO
U0TXD_out GPIO43
U0RTS_out GPIO 15
U0DTR_out Any GPIO
U1RXD_in GPIO 18
U1CTS_in GPIO 20
U1DSR_in Any GPIO
U1TXD_out GPIO 17
U1RTS_out GPIO 19
U1DTR_out Any GPIO
U2 Any GPIO
I2C Any GPIO
PWM Any GPIO
I2S Any GPIO
LCD Any GPIO
CAMERA Any GPIO
RMT Any GPIO
SPI2/3 Any GPIO
Pulse Counter Any GPIO
USB OTG D- GPIO 19 (internal PHY)
D+ GPIO 20 (internal PHY)
VP GPIO 42 (External PHY)
VM GPIO 41 (External PHY)
RCV GPIO21 (External PHY)
OEN GPIO 40 (External PHY)
VPO GPIO 39 (External PHY)
VMO GPIO38 (External PHY)
USB Serial/JTAG D- GPIO 19 (internal PHY)
SD/MMC Any GPIO
MCPWM Any GPIO
TWAI Any GPIO
Color LED GPIO 48
ESP-IDF
ESP-IDF is an IoT development framework officially launched by Espressif, supporting Windows, Linux and macOS operating systems.
It is recommended that developers install ESP-IDF via an integrated development environment (IDE):
Or select the corresponding manual installation process according to the operating system:
API:
In order to enable your BPI-Leaf-S3 development board to flash FLASH through USB-CDC, you need to set the development board to firmware download mode.
There are two methods of operation:
1. Connect to the computer via USB, press and hold the BOOT button, then press the RESET button and release it, and finally release the BOOT button.
2. Press and hold the BOOT button when the power supply is disconnected, then connect to the computer via USB, and finally release the BOOT button.
You need to confirm the interface in the device manager. The serial number of the interface in the firmware download mode and the normal mode may be different.
MicroPython
MicroPython implements most of the features and syntax of Python 3, which is easy to learn and use, and can be downloaded directly into the chip to run the verification program without compiling.
Regardless of whether you have a programming foundation or not, MicroPython is far less difficult to get started with than other programming languages. Its code is easy to read, and the open source community has accumulated rich resources over the years. Just like Python, it has strong vitality and application value.
Arduino
