BPI-PicoW-S3
About BPI-PicoW-S3
BPI-PicoW-S3 with ESP32-S3
BPI-Leaf-S3 with ESP32-S3
BPI-Smart with ESP8266
BPI-Bit with ESP32
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
key features
  • ESP32-S3,Xtensa® 32 bit LX7
  • 片外 PSRAM , FLASH
  • Ultra-low power 10uA
  • 1 * microUSB
  • 1 * 全彩色LED
BPI-PicoW-S3 VS Rraspberry Pi PicoW、BPI-Leaf-S3、ESP32-S3-DevKitC-1
开发板 BPI-PicoW-S3 Rraspberry Pi PicoW BPI-Leaf-S3 ESP32-S3-DevKitC-1
引出GPIO 27 27 36 36
3.3v管脚 1 1 2 2
5v管脚 2 2 1 1
GND管脚 8 8 4 4
全彩LED灯 1 on GPIO48 1 on GPIO48 1 on GPIO48
芯片直连USB MicroUSB接口x1 MicroUSB接口x1 Type-C USB接口x1 MicroUSB接口x1
UART TTL转USB CP2102-MicroUSB接口x1
外接电池连接座 3.7v锂电池供电接口
电池充电 500mA充电
I²C 4pin连接座 1
Espressif ESP32-S3
  • AI Acceleration Support: ESP32-S3 has additional support for vector instructions in the MCU, which provides acceleration for neural network computing and signal processing workloads. The software libraries for the above-mentioned optimized functions will become available very soon, in the form of updates to ESP-WHO and ESP-Skainet.
  • Rich Set of IO Peripherals: ESP32-S3 has 44 programmable GPIOs, namely 10 more GPIOs than those of ESP32. ESP32-S3 supports all the commonly-used peripherals, such as SPI, I2S, I2C, PWM, RMT, ADC and UART, SD/MMC host and TWAITM. In total, 14 GPIOs can be configured as capacitive touch input for HMI applications. Apart from all these peripherals, however, ESP32-S3 is also equipped with an ultra-low-power (ULP) core that supports multiple low-power modes in a variety of such use-cases.
  • Security:ESP32-S3 provides all the necessary security requirements for building securely connected devices, without requiring any external components. It supports AES-XTS-based flash encryption and RSA-based secure boot. In addition, ESP32-S3 has a digital signature peripheral and an HMAC module, which provide functionality that is similar to the hardware secure element, thus protecting the private or symmetric key from software attacks and identity theft. ESP32-S3 also has a “World Controller” peripheral that provides two fully-isolated execution environments, which enable the implementation of a trusted-execution environment or a privilege-separation scheme.
BPI-PicoW-S3 规格表
SoC ESP32-S3,Xtensa® 32 位 LX7 dual core
主频 240MHz MAX
工作温度 -40℃~+85℃
片上 ROM 384 KB
片上 SRAM 320 KB
板载 FLASH ROM 2MB
片上外设PSRAM 8MB
GPIO BPI-PicoW-S3已引出27个可用GPIO
ADC 2 × 12 位 SAR ADC,支持 18 个模拟通道输入
TOUCH 电容式触摸传感器 14
SPI 4
I2C 2,支持主机或从机模式
I2S 2,串行立体声数据的输入输出
LCD 1,支持 8 位 ~16 位并行 RGB、I8080、MOTO6800 接口
CAMERA 1,支持 8 位 ~16 位 DVP 图像传感器接口
UART 3 ,支持异步通信(RS232 和RS485)和 IrDA
PWM 8 路独立通道,14位精度
MCPWM 2
USB 1 × 全速USB 2.0 OTG,MicroUSB母口
温度传感器 1,测量范围为–20 °C 到 110 °C,用于监测芯片内部温度
SD/MMC 1 × SDIO主机接口,具有2个卡槽,支持SD卡3.0和3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5和4.51
TWAI® 控制器 1 ,兼容 ISO11898-1(CAN 规范 2.0)
通用 DMA 控制器 5 个接收通道和 5 个发送通道
RMT 4 通道发射,4通道接收,共享 384 x 32-bit 的 RAM
脉冲计数器 4个脉冲计数控制器(单元),每个单元有2个独立的通道
定时器 4 × 54 位通用定时器,16 位时钟预分频器,1 × 52 位系统定时器,3 × 看门狗定时器
外部晶振 40Mhz
低功耗电流 10uA
工作电压 3.3V
输入电压 3.3V~5.5V
最大放电电流 [email protected] DC/DC
可控全彩色LED 1
Size
BPI-PicoW-S3 尺寸表
管脚间距 2.54mm
安装孔间距 11.4mm/ 47mm
安装孔尺寸 内径2.1mm/外径3.4mm
主板尺寸 21 × 51.88(mm)/0.83 x 2.04(inches)
板厚 1.2mm
GPIO define
BPI-PicoW-S3 外设GPIO管脚分配
外设接口 信号 管脚
ADC ADC1_CH0~9 GPIO 1~10
ADC2_CH0~9 GPIO 11~20
触摸传感器 TOUCH1~14 GPIO 1~14
JTAG MTCK GPIO 39
MTDO GPIO 40
MTDI GPIO 41
MTMS GPIO 42
UART 默认分配管脚,可重定义为任意GPIO
U0RXD_in GPIO 44
U0CTS_in GPIO 16
U0DSR_in 任意GPIO
U0TXD_out GPIO43
U0RTS_out GPIO 15
U0DTR_out 任意GPIO
U1RXD_in GPIO 18
U1CTS_in GPIO 20
U1DSR_in 任意GPIO
U1TXD_out GPIO 17
U1RTS_out GPIO 19
U1DTR_out 任意GPIO
U2 任意GPIO
I2C 任意GPIO
PWM 任意GPIO
I2S 任意GPIO
LCD 任意GPIO
CAMERA 任意GPIO
RMT 任意GPIO
SPI0/1 已用于FLASH与PSRAM
SPI2/3 任意GPIO
脉冲计数器 任意GPIO
USB OTG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
RCV GPIO21(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
USB Serial/JTAG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
SD/MMC 任意GPIO
MCPWM 任意GPIO
TWAI 任意GPIO
彩色LED GPIO 48
ESP-IDF
或者根据操作系统选择对应的手动安装流程:
API:
有两种操作方法:
MicroPython
Arduino
