BPI-Bit-S2
Revision as of 06:16, 14 September 2022 by Wind (talk | contribs) (→key features)
About BPI:bit Lite
BPI-Bit Lite with ESP32-S2
BPI-Bit with ESP32
BPI-Leaf-S3 with ESP32-S3
BPI-AI Kendryte K210 RISC-V
BPI-UNO32 with ESP32 design
File:BPI-Bit V2 banner.jpg
BPI:Bit Lite development board is a successor to BPI:Bit, inheriting most of the core hardware functions.
key features
  • ESP32-S2
  • 5x5 RGB LED matrix
  • 1 buzzer
  • 1 thermosensitive sensor
  • 2 photosensitive sensors
  • 2 buttons on the front, 1 reset button and 1 boot button on the back.
  • Type-C USB interface
  • Size 5x5cm
  • The Goldfinger Edge Connector definition is fully compatible with Micro: Bit
Hardware upgrade and function comparison
BPI:Bit VS BPI:Bit Lite
Module BPI:Bit BPI:Bit Lite
SoC control chip ESP32 ESP32-S2
ROM 448 KB 128 KB
RAM 520 KB 320 KB
FlASH ROM 4096 KB 4096 KB
PSRAM None 2048 KB
Wireless Capability WIFI,Bluetooth WIFI
all-color LED 25 WS2812-5050 Lamp beads 25 WS2812-3535 Lamp beads
Key 2 programmable keys,1 RST key 2 programmable keys,1 BOOT key,1 RST key
buzzer 5.3x5.3mm buzzer 8.5x8.5mm buzzer
USB interface Micro USB Type-C USB
USB to TTL support None
battery interface support None
IO 19 pin Goldfinger IO(Compatible with Micro :bit accessories ) 19 pin Goldfinger IO(Compatible with Micro :bit accessories ),Crocodile clip bayonet with 19 pin contacts on the back
Nine-axis sensor support None
photosensitive sensor 2 2
temperature sensor 1 1
BPI:Bit Lite specification
SoC ESP32-S2FN4R2,Xtensa® 32 bit LX7 Single-Core Processer
frequency 240MHz MAX
operating temperature -40℃~+85℃
ROM 128 KB
SRAM 320 KB
FLASH ROM 4 MB
PSRAM 2 MB
WIFI IEEE 802.11 b/g/n ,2.4Ghz
GPIO 19 available GPIO pins have been introduced and peripheral functions are available:ADC,TOUCH,PWM,SPI,I2C,I2S,Pulse counter, RMT,TWAI® Controller,SD/MMC,LCD_CAMERA
external crystal 40Mhz
Buzzer 8.5x8.5mm buzzer
LED 25 Series full color LED lamp, single line GPIO control; 1 monochrome LED, CONTROLLED by GPIO
photosensitive sensor 2 photosensitive sensor
photosensitive sensor 1 photosensitive sensor
IO 19pins 19 pin Goldfinger IO(Compatible with Micro :bit accessories ),Crocodile clip bayonet with 19 pin contacts on the back
Key 2 Programmable buttons,1 BOOT botton,1 reset key
USB USB Type-C interface,full speed USB OTG,USB-ACM
operating voltage 3.3V
Power USB Type-C input 5V,or Goldfinger IO input 3.3V power supply
size 5 * 5 cm
On-board peripherals
Peripheral GPIO allocation and signal type
photosensitive sensor(L) GPIO 12 Analog Input
photosensitive sensor(R) GPIO 13 Analog Input
Key A GPIO 38 Digital Input
Key B GPIO 33 Digital Input
Key BOOT GPIO 0 Digital Input
temperature sensor GPIO 14 Analog Input
buzzer GPIO 17 PWM(Digital Output)
RGB_LED GPIO 18 Digital Output
5*5 Full color LED lights
BPI:Bit V2 have 25 Full color LED lights , single GPIO ontrol.The three primary color pixels of each LED can achieve 8bit 256 level brightness display, and achieve 16777216 color full color display, scanning frequency is not less than 400Hz/s.
5*5 LEDs list of BPI:Bit V2
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
Goldfinger GPIO define
BPI:Bit Lite Gold finger GPIO is defined to be compatible with Micro :Bit. GPIO expansion board accessories can be used with Micro: Bit.
SPI,I2C
Function Pin Name GPIO Num
SPI_SCK P13 GPIO36
SPI_MISO P14 GPIO37
SPI_MOSI P15 GPIO35
SPI_CS P16 GPIO34
I2C_SCL P19 GPIO16
I2C_SDA P20 GPIO15
Power
BPI:Bit Lite supports two power supply modes
Webduino
webduino在线积木编程平台
webduino积木编程平台 Windows安装版
webduino在线教学手册
Arduino
Preparing...
MicroPython
Preparing...
BPI-Bit Lite schematic
