BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
- File and burn position corresponding to::
| Matrix-2'8_SPI_Key_TFT-1706 | |||
| Pin# | file name | Position | |
- SpiFlashConfig:
| SPI SPEED | 40NHz |
| SPI MODE | DIO |
| FLASH SIZE | 32Mbit |
| COM | COMx(Fill in the port number assigned by the computer) |
| BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
