Getting Started with BPI-R3
- . 2G DDR RAM
- . 8G eMMC flash
- . 2 SFP 2.5GbE
- . 5 GbE network port
- . POE support (optional)
- . Mini PCIe via USB
- . M.2 KEY-E PCIe inerface
- . Mciro SD card interfact
- . 26 PIN GPIO
* Prepare 8G/above TF card, USB-Serial interface, Ubuntu System * Using your USB-Serial Connect debug console on BPI-R3
* R3 bootstrap and device select Jumper Setting
Note: SW1-A and SW1-B is for boot strap selecting;
SW1-C is that SPI-Nand or SPI-Nor Device is connected to CPU's SPI bus;
SW1-D is that SD Card or EMMC device is connected tp CPU's EMMC bus.
How to burn image to SD card
A. Note: burn image to SD card on linux computer 1.You could download latest image from our forum * Here is the example image link: 2.Install bpi-tools on your Ubuntu. If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually. * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card 4.After step 3, then you can insert your TF card into R3, and press power button to setup R3 B. Note: burn image to SD card on windows computer 1. Download the tools from the website: https://sourceforge.net/projects/win32diskimager/ 2. Install the tools into Windows computer. 3. flash image into SD card.
Note: because SD card and EMMC device share one SOC's interface, you need flash one SD image firstly, then R3 boot from SD card, then flash nand image into Nand, then change boot strap to boot from nand, you need flash EMMC image into EMMC. Finally you change bootstrap to boot from EMMC.
* mtd erase /dev/mtd0
* dd if=mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bi of=/dev/mtdblock0
Network-Configuration
- Network Interface: eth1, lan0 is for WAN; lan4, rax0, lan2, lan5, ra0, lan3, lan1 is for LAN, ra0 is for 2.4G wireless, rax0 is for 5G wireless.
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
Interrupt:6
root@OpenWrt:/#
GPIO
26 Pins Definition
PWM FAN Control
miniPCIe slot
Ap mode on BPI-R3
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
