Banana Pi BPI-M2S
BPI-M2S Introduction
BananaPi BPI-M2S new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port . 4G RAM and 16 GB eMMC flash.Amlogic S922X variant M2S board is not support npu, mipi panel and mipi camera.BPI-M2S same size as Banana Pi BPI-M2+ and Banana Pi BPI-M2 Pro
- 4GB LPDDR4 RAM
- 16GB eMMC flash (Max 128G)
- 2 Gigabit port
- HDMI output
- 40 PIN GPIO
- System Memory – 4GB LPDDR4
- Video interfaces
- HDMI 2.1 output up to 4Kp60
- Misc – 3x buttons
- Dimensions – 65 x 65mm
PoE Wifi&BT
BPI-M2S 40PIN GPIO (CON2)
| GPIO Pin Name | Default :GPIO | Function2 | Function3 |
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | DCIN | ||
| CON2-P03 | GPIOX_17 | I2C_EE_M2_SDA | BT_EN |
| CON2-P04 | DCIN | ||
| CON2-P05 | GPIOX_18 | I2C_EE_M2_SCL | BT_WAKE_HOST |
| CON2-P06 | GND | ||
| CON2-P07 | GPIOX_5 | PWM_C | WIFI_SD_CMD |
| CON2-P08 | GPIOX_12 | UART_EE_A_TX | |
| CON2-P09 | GND | ||
| CON2-P10 | GPIOX_13 | UART_EE_A_RX | |
| CON2-P11 | GPIOX_3 | WIFI_SD_D3 | |
| CON2-P12 | GPIOA_1 | I2SB_SCLK | |
| CON2-P13 | GPIOX_4 | WIFI_SD_CLK | |
| CON2-P14 | GND | ||
| CON2-P15 | GPIOX_7 | WIFI_WAKE_HOST | |
| CON2-P16 | GPIOX_0 | WIFI_SD_D0 | |
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | GPIOX_1 | WIFI_SD_D1 | |
| CON2-P19 | GPIOX_8 | SPI_A_MOSI | BTPCM_DIN |
| CON2-P20 | GND | ||
| CON2-P21 | GPIOX_9 | SPI_A_MISO | BTPCM_DOUT |
| CON2-P22 | GPIOX_2 | WIFI_SD_D2 | |
| CON2-P23 | GPIOX_11 | SPI_A_CLK | BTPCM_CLK |
| CON2-P24 | GPIOX_10 | SPI_A_CS | BTPCM_SYNC |
| CON2-P25 | GND | ||
| CON2-P26 | GPIOX_16 | BT_32K | |
| CON2-P27 | GPIOH_5 | ||
| CON2-P28 | GPIOH_4 | ||
| CON2-P29 | GPIOX_14 | BTUART_A_CTS_N | |
| CON2-P30 | GND | ||
| CON2-P31 | GPIOX_15 | BTUART_A_RTS_N | |
| CON2-P32 | GPIOX_19 | HOST_WAKE_BT | |
| CON2-P33 | GPIOX_6 | WIFI_PWREN | |
| CON2-P34 | GND | ||
| CON2-P35 | GPIOA_2 | I2SB_LRCLK | |
| CON2-P36 | GPIOAO_5 | IR_IN | |
| CON2-P37 | GPIOA_0 | I2S_MCLK_0 | |
| CON2-P38 | GPIOA_4 | I2SB_DOUT_DIN_1 | |
| CON2-P39 | GND | ||
| CON2-P40 | GPIOA_3 | I2SB_DOUT_DIN_0 |
BPI-M2S Debug UART(CON1)
| CON2-P1 | GND |
| CON2-P2 | UART0-RX |
| CON2-P3 | UART0-TX |
BPI-M2S Camera(CN10)
| CSI Pin Name | Default Function | Function2:GPIO |
| CN10-P01 | GND | |
| CN10-P02 | MIPI_CSI_D3N | |
| CN10-P03 | MIPI_CSI_D3P | |
| CN10-P04 | GND | |
| CN10-P05 | MIPI_CSI_D2N | |
| CN10-P06 | MIPI_CSI_D2P | |
| CN10-P07 | GND | |
| CN10-P08 | MIPI_CSI_CLKBN | |
| CN10-P09 | MIPI_CSI_CLKBP | |
| CN10-P10 | GND | |
| CN10-P11 | MIPI_CSI_D1N | |
| CN10-P12 | MIPI_CSI_D1P | |
| CN10-P13 | GND | |
| CN10-P14 | MIPI_CSI_D0N | |
| CN10-P15 | MIPI_CSI_D0P | |
| CN10-P16 | GND | |
| CN10-P17 | MIPI_CSI_CLKAN | |
| CN10-P18 | MIPI_CSI_CLKAP | |
| CN10-P19 | NC | |
| CN10-P20 | CAM0_MCLK | |
| CN10-P21 | CAM0_IRCUT | |
| CN10-P22 | CAM0_SCL | |
| CN10-P23 | CAM0_SDA | |
| CN10-P24 | CAM0_RESET | |
| CN10-P25 | VCC1V8_DOVDD | |
| CN10-P26 | GND | |
| CN10-P27 | GND | |
| CN10-P28 | VCC33 | |
| CN10-P29 | VCC33 | |
| CN10-P30 | VCC33 |
BPI-M2S LCD(CN9)
| DSI Pin Name | Default Function | Function2:GPIO |
| CN9-P01 | MIPI_D0_N | |
| CN9-P02 | MIPI_D0_P | |
| CN9-P03 | MIPI_D1_N | |
| CN9-P04 | MIPI_D1_P | |
| CN9-P05 | MIPI_CLK_N | |
| CN9-P06 | MIPI_CLK_P | |
| CN9-P07 | MIPI_D2_N | |
| CN9-P08 | MIPI_D2_P | |
| CN9-P09 | MIPI_D3_N | |
| CN9-P10 | MIPI_D3_P | |
| CN9-P11 | TP_INT_3V3 | |
| CN9-P12 | TP_RST_3V3 | |
| CN9-P13 | I2C_M3_SCL_3V3 | |
| CN9-P14 | I2C_M3_SDA_3V3 | |
| CN9-P15 | LCD_BL_EN_3V3 | |
| CN9-P16 | LCD_PWM_3V3 | |
| CN9-P17 | GND | |
| CN9-P18 | GND | |
| CN9-P19 | VLCD_5V | |
| CN9-P20 | VLCD_5V |
- All Android and Linux image google link: https://drive.google.com/drive/folders/1tv-oFOPb9pHwU2J2YLm__T2b-2W6WQ00
- All Android and Linux image Baidu link: https://pan.baidu.com/s/1ZydjIkTczXr8EdCiXPIIJg?pwd=pxcn Pincode: pxcn
Android 9
- Android 9 image , 2022-06-23 update
- google drive: https://drive.google.com/drive/folders/1z0-TSx0vnNBbrMIQaphTsS_nuZaNwHDY?usp=sharing
- baidu link:https://pan.baidu.com/s/1hN1_pAniED3SusDGPnyg-A?pwd=duks pincode: duks
debian
- debian 10 buster 2022-06-23 update
ubuntu Linux
- Ubuntu 20.04 desktop aarch64 2022-06-23 update
- Ubuntu 20.04 server aarch64 2022-06-23 update
