Getting Started with M2S
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
IR Remote Control Custom
- Android keycode.
- push remote.cfg back
- 3. Get the remote keycode
- custom_code = 0xfe01
- 5. Reboot the board
Install Image to SDcard
Install Image to EMMC
Build Linux Source Code
Custom Linux Boot Logo
Custom Android Boot Logo
- 4. Extract this tool
Boot Sequence
bananapi_m5_v1#
bananapi_m5# mmc erase 0 1000
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
- Linux Wifi STA mode
network:
version: 2
renderer: networkd
wifis:
wlan0:
dhcp4: true
access-points:
"bananapi":
password: "123456789"
- Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 2.4GHz
channel: 6
auth:
key-management: psk
network:
version: 2
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 5GHz
channel: 36
auth:
key-management: psk
network:
version: 2
renderer: networkd
ethernets:
wlan0:
dhcp4: no
addresses:
- 192.168.11.1/24
- 2). Install hostapd
$ sudo apt install hostapd
option routers 192.168.11.1;
- 5). Start Service
- 6). Routing configuration.
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Install Docker Engine
- 1. Set up the repository
$ echo \
- 2. Install Docker Engine
$ sudo docker run hello-world
