Getting Started with M5/M2Pro
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
IR Remote Control Custom
- Android keycode.
- push remote.cfg back
- 3. Get the remote keycode
- custom_code = 0xfe01
- 5. Reboot the board
Install Image to SDcard
Install Image to EMMC
=Setting up Banana Pi with Ubuntu 20.04 Server from a Windows PC
Download latest version of Balena Etcher Download image file from: Banana Pi Open Source Project (banana-pi.dev) 2 2021-06-21-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img.zip Unzip the image file to a folder on your Windows machine Used Balena Etcher to flash the unzipped image file (*.img) to an SD card Copy the zipped (*.zip) version of the same file to a USB thumb drive (I had to reformat the USB drive to NTFS file system to copy the file to the USB stick…not sure why) Boot up the Bpi M5 with the SD card Login for Ubuntu was ‘pi’ with password ‘bananapi” Can STOP HERE IF YOU JUST WANT TO BOOT UBUNTU FROM SD CARD CONTINUE IF YOU WANT TO CONFIGURE M5 TO BOOT UBUNTU FROM EMMC If you proceed, you will no longer be able to boot from the SD card until you reformat EMMC Login for Ubuntu was ‘pi’ with password ‘bananapi” At the terminal prompt $, ran these two commands: sudo apt-get install pv curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash Insert the USB thumb drive into Bpi M5 and mount in via terminal $ using these commands: sudo fdisk -l Used to see what the OS is naming your USB drive Mine was /dev/sda1 sudo mkdir /media/usb Used to make a directory (mount point) for mounting the USB drive. This directory may already exist. cd /media/usb sudo mount /dev/sda1 /media/usb Used to mount the USB drive to the /media/usb folder ls Lists the contents of the USB drive. Should see your *.zip version of the Ubuntu image file sudo bpi-copy 2021-06-21-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img.zip /dev/mmcblk0 Copies, unzips, and installs the image file onto the EMMC I got an error at this point related to “unzip” not being a valid command I just ran the command: sudo apt-get install unzip Re-ran the command: sudo bpi-copy… listed above The boot order for the Bpi M5 is Start ROM:Boot EMMC and then Boot SD Card, so if you want to go back to booting from the SD Card after installing an OS on the EMMC, you will have to erase it first and start over. To erase the EMMC for SD Card bootup: Connect the M5 to your computer via USB debug console cable Use the Amlogic USB Burning Tool to format the EMMC
Build Linux Source Code
Custom Linux Boot Logo
Custom Android Boot Logo
- 4. Extract this tool
Boot Sequence
bananapi_m5_v1#
bananapi_m5# mmc erase 0 1000
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
- Linux Wifi STA mode
- Linux Wifi AP mode
$ iw list
- 2). Install hostapd
$ sudo apt install hostapd
- 5). Start Service
- 6). Routing configuration.
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Install Docker Engine
- 1. Set up the repository
$ echo \ "deb [arch=arm64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg]https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
- 2. Install Docker Engine
$ sudo docker run hello-world
