BPI-Leaf-S3
Revision as of 18:33, 2 March 2022 by Wind (talk | contribs) (Hardware Dimensions)
The Banana Pi Leaf series are low-power microcontrollers designed for the Internet of Things.
The Leaf-S3's onboard ESP32-S3 chip is powered by an Xtensa® 32-bit LX7 dual-core processor with a main frequency of up to 240 MHz.
It supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, the peripheral is compatible with low-power hardware design, and the power consumption is only 10uA in deep sleep mode.
The main controller supports two power supply modes: USB and external 3.7V lithium battery, which can realize the function of automatic power switching under dual power supply, and supports USB charging mode. Small size, convenient interface, easy to use, and can be directly applied to low-power IoT projects.
In terms of programming, Leaf-S3 motherboard supports ESP-IDF, Arduino, micropython and other methods for programming and development.
All IO pins corresponding to the chip are marked on the Leaf-S3 motherboard, which lowers the threshold for use.
  • ESP32-S3,Xtensa® 32 bit LX7
  • External PSRAM , FLASH
  • Ultra-low power 10uA
  • 1* 4pin I2C connector
  • 1 * USB Type-C
  • 1 * 2pin battery connector,support charging
  • 1 * Neopixel LED
Hardware sketch map
Hardware Spec
BPI-Leaf-S3 Spec
SoC ESP32-S3,Xtensa® dual-core 32-bit LX7 microprocessor
Clock Frequency 240MHz MAX
Ambient Temperature -40℃~+85℃
Internal ROM 384 KB
Internal SRAM 320 KB
External FLASH ROM 8MB
External PSRAM 8MB
WIFI IEEE 802.11 b/g/n ,2.4Ghz,150Mbps
Bluetooth Bluetooth 5 ,Bluetooth mesh
GPIO BPI-Leaf-S3 has led out 36 available gpios
ADC 2 × 12-bit SAR ADCs, up to 20 channels
Touch Sensor 14
SPI 4
I2C 2
I2S 2
LCD 1 × LCD interface (8-bit ~16-bit parallel RGB, I8080 and MOTO6800)
CAMERA 1 × DVP 8-bit ~16-bit camera interface
UART 3
PWM 8 channels 14 bits
MCPWM 2
USB 1 × full-speed USB OTG,female Type-C socket
USB Serial/JTAG controller 1,CDC-ACM ,JTAG
Temperature sensor 1,range of –20 °C to 110 °C
SD/MMC 1 × SDIO host controller with 2 slots,SD 3.0,SD 3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5,eMMC 4.51
TWAI® controller 1 ,compatible with ISO 11898-1 (CAN Specification 2.0)
General DMA controller (GDMA) 5 transmit channels and 5 receive channels
RMT 4 TX channels,4RX channels.Eight channels share a 384 x 32-bit RAM
Pulse Count Controller 4 independent pulse counters (units).Each unit consists of two independent channels
Timers 4 × 54-bit general-purpose timers.1 × 52-bit system timer.3 × watchdog timers
External crystal oscillator 40Mhz
RTC and Low­Power Management Power Management Unit (PMU) + Ultra-­Low-­Power Coprocessor(ULP)
Deep-sleep consumption current 10uA
Operating Voltage 3.3V
Input Voltage 3.3V~5.5V
Maximum discharge current 2A@3.3V LDO
USB charge Support
Maximum charging current 500mA
Neopixel LED 1
Hardware Dimensions
BPI-Leaf-S3 Dimensions
Pin spacing 2.54mm
Mounting hole spacing 23mm/ 62.25mm
Mounting hole size bore 2mm/outside 3mm
Motherboard size 26 × 65.25(mm)/1.02 x 2.57(inches)
board thickness 1.2mm
GPIO Pin define
BPI-Leaf-S3 GPIO Pin define
外设接口 信号 管脚
ADC ADC1_CH0~9 GPIO 1~10
ADC2_CH0~9 GPIO 11~20
触摸传感器 TOUCH1~14 GPIO 1~14
JTAG MTCK GPIO 39
MTDO GPIO 40
MTDI GPIO 41
MTMS GPIO 42
UART 默认分配管脚,可重定义为任意GPIO
U0RXD_in GPIO 44
U0CTS_in GPIO 16
U0DSR_in 任意GPIO
U0TXD_out GPIO43
U0RTS_out GPIO 15
U0DTR_out 任意GPIO
U1RXD_in GPIO 18
U1CTS_in GPIO 20
U1DSR_in 任意GPIO
U1TXD_out GPIO 17
U1RTS_out GPIO 19
U1DTR_out 任意GPIO
U2 任意GPIO
I2C 任意GPIO
PWM 任意GPIO
I2S 任意GPIO
LCD 任意GPIO
CAMERA 任意GPIO
RMT 任意GPIO
SPI0/1 已用于FLASH与PSRAM
SPI2/3 任意GPIO
脉冲计数器 任意GPIO
USB OTG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
RCV GPIO21(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
USB Serial/JTAG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
SD/MMC 任意GPIO
MCPWM 任意GPIO
TWAI 任意GPIO
彩色LED GPIO 48
