BPI-Leaf-S3
The Banana Pi Leaf series are low-power microcontrollers designed for the Internet of Things.
The Leaf-S3's onboard ESP32-S3 chip is powered by an Xtensa® 32-bit LX7 dual-core processor with a main frequency of up to 240 MHz.
It supports 2.4 GHz Wi-Fi and Bluetooth® LE dual-mode wireless communication, the peripheral is compatible with low-power hardware design, and the power consumption is only 10uA in deep sleep mode.
The main controller supports two power supply modes: USB and external 3.7V lithium battery, which can realize the function of automatic power switching under dual power supply, and supports USB charging mode. Small size, convenient interface, easy to use, and can be directly applied to low-power IoT projects.
In terms of programming, Leaf-S3 motherboard supports ESP-IDF, Arduino, micropython and other methods for programming and development.
All IO pins corresponding to the chip are marked on the Leaf-S3 motherboard, which lowers the threshold for use.
  • ESP32-S3,Xtensa® 32 bit LX7
  • External PSRAM , FLASH
  • Ultra-low power 10uA
  • 1* 4pin I2C connector
  • 1 * USB Type-C
  • 1 * 2pin battery connector,support charging
  • 1 * Neopixel LED
Hardware sketch map
Hardware Spec
BPI-Leaf-S3 Spec
SoC ESP32-S3,Xtensa® dual-core 32-bit LX7 microprocessor
Clock Frequency 240MHz MAX
Ambient Temperature -40℃~+85℃
Internal ROM 384 KB
Internal SRAM 320 KB
External FLASH ROM 8MB
External PSRAM 8MB
WIFI IEEE 802.11 b/g/n ,2.4Ghz,150Mbps
Bluetooth Bluetooth 5 ,Bluetooth mesh
GPIO BPI-Leaf-S3 has led out 36 available gpios
ADC 2 × 12 位 SAR ADC,支持 20 个模拟通道输入
TOUCH 电容式触摸传感器 14
SPI 4
I2C 2,支持主机或从机模式
I2S 2,串行立体声数据的输入输出
LCD 1,支持 8 位 ~16 位并行 RGB、I8080、MOTO6800 接口
CAMERA 1,支持 8 位 ~16 位 DVP 图像传感器接口
UART 3 ,支持异步通信(RS232 和RS485)和 IrDA
PWM 8 路独立通道,14位精度
MCPWM 2
USB 1 × 全速USB 2.0 OTG,Type-C母口
温度传感器 1,测量范围为–20 °C 到 110 °C,用于监测芯片内部温度
SD/MMC 1 × SDIO主机接口,具有2个卡槽,支持SD卡3.0和3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5和4.51
TWAI® 控制器 1 ,兼容 ISO11898-1(CAN 规范 2.0)
通用 DMA 控制器 5 个接收通道和 5 个发送通道
RMT 4 通道发射,4通道接收,共享 384 x 32-bit 的 RAM
脉冲计数器 4个脉冲计数控制器(单元),每个单元有2个独立的通道
定时器 4 × 54 位通用定时器,16 位时钟预分频器,1 × 52 位系统定时器,3 × 看门狗定时器
外部晶振 40Mhz
低功耗电流 10uA
工作电压 3.3V
输入电压 3.3V~5.5V
最大放电电流 [email protected] LDO
USB充电 支持
最大充电电流 500mA
可控全彩色LED 1
Hardware Dimensions
BPI-Leaf-S3 Dimensions
管脚间距 2.54mm
安装孔间距 23mm/ 62.25mm
安装孔尺寸 内径2mm/外径3mm
主板尺寸 26 × 65.25(mm)/1.02 x 2.57(inches)
板厚 1.2mm
GPIO Pin define
BPI-Leaf-S3 GPIO Pin define
外设接口 信号 管脚
ADC ADC1_CH0~9 GPIO 1~10
ADC2_CH0~9 GPIO 11~20
触摸传感器 TOUCH1~14 GPIO 1~14
JTAG MTCK GPIO 39
MTDO GPIO 40
MTDI GPIO 41
MTMS GPIO 42
UART 默认分配管脚,可重定义为任意GPIO
U0RXD_in GPIO 44
U0CTS_in GPIO 16
U0DSR_in 任意GPIO
U0TXD_out GPIO43
U0RTS_out GPIO 15
U0DTR_out 任意GPIO
U1RXD_in GPIO 18
U1CTS_in GPIO 20
U1DSR_in 任意GPIO
U1TXD_out GPIO 17
U1RTS_out GPIO 19
U1DTR_out 任意GPIO
U2 任意GPIO
I2C 任意GPIO
PWM 任意GPIO
I2S 任意GPIO
LCD 任意GPIO
CAMERA 任意GPIO
RMT 任意GPIO
SPI0/1 已用于FLASH与PSRAM
SPI2/3 任意GPIO
脉冲计数器 任意GPIO
USB OTG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
RCV GPIO21(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
USB Serial/JTAG D- GPIO 19(内部 PHY)
D+ GPIO 20(内部 PHY)
VP GPIO 42(外部 PHY)
VM GPIO 41(外部 PHY)
OEN GPIO 40(外部 PHY)
VPO GPIO 39(外部 PHY)
VMO GPIO38(外部 PHY)
SD/MMC 任意GPIO
MCPWM 任意GPIO
TWAI 任意GPIO
彩色LED GPIO 48
