BPI-7604 IEEE 802.3af PoE Splitter module
Revision as of 07:13, 28 February 2022 by Sinovoip (talk | contribs)
Description
BPI-9460 IEEE 802.3af Isolation Model PoE module
BPI-7604 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. BPI-7604 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. BPI-7604 provides a Class 0 signature. BPI-7604 DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Application
  • IP Cameras
  • Wireless access point
  • Security and alarm systems
  • VOIP telephone
Main sprc
  • IEEE802.3af compliant
  • Integrated LAN Filters
  • Regulated 12V DC output
  • Low output ripple and noise
  • Wide Input voltage range
  • Overload and short-circuit protection
  • 1500V isolation (input to output)
  • Simple installation
  • CE and FCC part 15 certified
  • Enables PoE functionality for legacy products
Specification
1 Input Voltage: 36 to 57 Vdc
2 Output power: 13W max.
3 Output current and voltage: 1.08A max. @ 12V +/-0.5V
4 Ripple: Typical 100mVp-p
5 Connectors: 2 x 8pin 1x 4pin 1.25mm
6 Ethernet Supported: 10/100-Base-T IEEE 802.3af
7 PoE Pin Assignment: 3/6, 1/2 or 4/5, 7/8
8 Storage Temperature: -30°C to +80°C
9 Operating Humidity: 10% to 90%, non-condensing
10 Storage Humidity: 5% to 95%, non-condensing
11 Emissions & Immunity: FCC Part 15 Class A EN55022 (CISPR 22) Class B EN55024 (CISPR 24)
12 Safety: CE IEC 60950
13 Reliability MTBF: 100,000 hours @ 25°C
14 Warranty : 1 Year
15 Dimensions: Height: 38 mm Width: 38mm Depth: 18mm Weight: 20 g
16 Operating Temperature: -20°C to +70°C
Connector and Pin Description
J1 AUX IN 1.25mm J3 DC Putout 2 2.0mm
1 Ethernet cable spare pair 7,8 1 12V Output +
2 Ethernet cable spare pair 4,5 2 12V Output -
3 DC Auxiliary input 12V-
4 DC Auxiliary input 12V+
J2 POE_IN 1.25mm J4 NET out 1.25mm
1 LED- Internal connection J3 1 12V Output -
2 LED+ Internal connection J3 2 12V Output +
3 Ethernet cable 6 3 LED- Internal connection J1
4 Ethernet cable 3 4 LED+ Internal connection J1
5 Ethernet cable 2 5 Ethernet cable 1
6 Ethernet cable 1 6 Ethernet cable 2
7 Ethernet cable 3
8 Ethernet cable 6
Package Size
Typical Connection in IP Cameras
OEM&ODM
Products can be customized according to customer needs
