Banana Pi BPI-M5
BPI-M5 Introduction
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
Hardware inerface
| Memory | 4 GB LPDDR4 | ||
| OS | Android and Linux | ||
SDIO interface Wifi&BT
| Network | 1 GbE ,WiFi&BT5.0 onbard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
BPI-M5 40PIN GPIO (CON2)
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | VCC5V | ||
| CON1-P04 | VCC5V | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
| CON2-P1 | GND |
| CON2-P2 | UART0-RX |
| CON2-P3 | UART0-TX |
Linux BSP source code
- BPI-M5 schematic diagram
- BPI-M5 PCB DXF file
- Amlogic S905x3 datasheet
Third part image
CoreELEC
- CoreELEC 19.2
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
- Google drive:
- Baidu link
HuaWei OpenEuler
- Download:
