Getting Started with M2M
Revision as of 00:37, 24 March 2021 by Dangku (talk | contribs) (Development)
BPI-M2M
  • 512MB DDR3 SDRAM
1. Prepare 8G/above TF card, USB-Serial interface.
2. Connect USB-Serial to 40 pin header uart2 for kernel console debug.
Note: three pin header uart0 beside usb port is not debug uart for bpi release images because SDcard and uart0 are multiplex pin and default bpi images support both SD and eMMC. If you want bootup with emmc only and enable uart0 as debug port without SDcard support, please refer to enable uart0 debug for emmc only image section.
3. Install bpi-tools on your Linux PC, If you can't access this URL or any other problems, please go to bpi-tools repo and download this tools manually.
 $ apt-get install pv
4. Download latest linux image, and confirm that the md5 checksum is correct.
5. Defautl login: pi/bananapi or root/bananapi.
Install Image to SDcard
1. Install image with bpi-tools on Linux, plug your sd card to your Linux PC
   $ sudo bpi-copy  xxx-bpi-m2m-xxx.img.zip /dev/sdX
2. Install image with dd command on Linux, umount SDcard device /dev/sdX partitions if mounted automatically, Actually bpi-copy is the same as this dd command.
   $ sudo apt-get install pv
   $ sudo unzip -p xxx-bpi-m2m-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
3. Install bpi image with Etcher on Windows, Linux and MacOS
Install Image to EMMC
1. Prepare a SDcard with Linux image flashed and bootup the board with this SDcard.
2. Copy emmc image to udisk, plugin the udisk to board and mount it.
   $ sudo bpi-copy xxx-bpi-m2m-xxx.img.zip /dev/mmcblk1
4. Or Install with dd command, umount mmcblk1p1 and mmcblk1p2 partition if mounted automatically, Actually bpi-copy is the same as this dd command
   $ sudo unzip -p xxxb-bpi-m2m-xxx.img.zip | pv | dd of=/dev/mmcblk1 bs=10M status=noxfer
5. After flash complete, power off safely and eject the sdcard.
Note: If the emmc was flashed android image before, you must erase the boot partition of android before step 3 or step 4.
   root@bpi-iot-ros-ai:/# echo 0 > /sys/block/mmcblk1/mmcblk1boot0/force_ro
   root@bpi-iot-ros-ai:/# echo 0 > /sys/block/mmcblk1/mmcblk1boot1/force_ro
   root@bpi-iot-ros-ai:/# dd if=/dev/zero of=/dev/mmcblk1boot0 bs=4096 count=1024
   1024+0 records in
   1024+0 records out
   4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.421164 s, 10.0 MB/s
   root@bpi-iot-ros-ai:/# dd if=/dev/zero of=/dev/mmcblk1boot1 bs=4096 count=1024
   1024+0 records in
   1024+0 records out
   4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.428427 s, 9.8 MB/s
Build Source Code
1. Get the bsp source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-M2M-bsp
2. Build the bsp source code
Advance Development
Enable uart0 for emmc only image debug
1. Enable uart0 node and disable sdc0 node in sunxi-pack/sun8iw5p1/configs/BPI-M2M-LCD7/sys_config.fex.
    --- a/sunxi-pack/sun8iw5p1/configs/BPI-M2M-LCD7/sys_config.fex
    +++ b/sunxi-pack/sun8iw5p1/configs/BPI-M2M-LCD7/sys_config.fex
   @@ -262,7 +262,7 @@ twi_sda         = port:PE13<3><default><default><default>
    ;uart_type       = 2:2 wire,4:4 wire,8:8 wire, full function
    [uart0]
   -uart_used       = 0
   +uart_used       = 1
    uart_port       = 0
    uart_type       = 2
    uart_tx         = port:PF02<3><1><default><default>
   @@ -803,7 +803,7 @@ led3_active_low             = 1
    ;     that supports SD3.0 cards and eMMC4.4+ flashes
    [mmc0_para]
   -sdc_used          = 1
   +sdc_used          = 0
    sdc_detmode       = 3
    sdc_buswidth      = 4
    sdc_d1            = port:PF00<2><1><2><default>
2. Build the bsp source code.
3. Copy the bootloader file SD/bpi-m2m/100MB/BPI-M2M-LCD7-8k.img.gz to udisk.
4. Bootup the m2m board from emmc, plugin the udisk and mount it.
5. Flash the bootloader to emmc
   $ sudo bpi-bootsel BPI-M2M-LCD7-8k.img.gz /dev/mmcblk0
or
   $ sudo gunzip -c BPI-M2M-LCD7-8k.img.gz | dd of=/dev/mmcblk0 bs=1024 seek=8
   $ sync
   $ sudo umount /dev/sda1
6. Mout boot partition and set kernel debug console in uEnv.txt
   $ sudo mount -t vfat /dev/mmcblk0p1 /mnt
Change "console=ttyS2,115200" to "console=ttyS0,115200" in /mnt/bananapi/bpi-m2m/linux/lcd7/uEnv.txt
   $ sudo umount /dev/mmcblk0p1
7. Safely poweroff the board and connect debug uart to uart0 three pin header.
  • Execute "bluetoothctl"
  • Execute these commands:
 $ sudo su
 # killall wpa_supplicant
 # wpa_passphrase <ssid> <passphrase> > /etc/wpa_supplicant/wpa_supplicant.conf
 # ifconfig wlan0 up
 # iwlist wlan0 scan
 # wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
 # dhclient eth0
There are some other command line ways, please google for them.
StartX
  • apt-get install xorg
  • apt-get install xserver-xorg
  • apt-get install xinit
https://askubuntu.com/questions/518454/what-does-startx-command-do
NAS Application
1. Usb hub + sata to usb
  • HDD is supported
  • SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
