Getting Started with M2M
BPI-M2M
Overview:Banana Pi BPI-M2M
  • 512MB DDR3 SDRAM
1. Prepare 8G/above TF card, USB-Serial interface.
2. Connect USB-Serial to 40 pin header uart2 for kernel console debug, 3 pin header uart0 beside usb port is not debug uart for bpi release images.
3. Install bpi-tools on your Linux PC, If you can't access this URL or any other problems, please go to bpi-tools repo and download this tools manually.
 $ apt-get install pv
4. Download latest linux image, and confirm that the md5 checksum is correct.
5. Defautl login: pi/bananapi or root/bananapi.
Install Image to SDcard
1. Install image with bpi-tools on Linux, plug your sd card to your Linux PC
   $ sudo bpi-copy  xxx.img /dev/sdX
2. Install image with dd command on Linux, umount SDcard device /dev/sdX partitions if mounted automatically, Actually bpi-copy is the same as this dd command.
   $ sudo apt-get install pv
   $ sudo unzip -p xxx-bpi-m2m-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
3. Install bpi image with Etcher on Windows, Linux and MacOS
1. Prepare a SDcard Linux image flashed and bootup the board with this SDcard.
2. Copy emmc image to udisk, plugin the udisk to board and mount it.
   $ sudo bpi-copy xxx-bpi-m2m-xxx.img.zip /dev/mmcblk1
Note: If the emmc was flashed android image before, you must erase the boot partition of android before download linux image
4. Or Install with dd command, umount mmcblk1p1 and mmcblk1p2 partition if mounted automatically, Actually bpi-copy is the same as this dd command
   $ sudo unzip -p xxxb-bpi-m2m-xxx.img.zip | pv | dd of=/dev/mmcblk1 bs=10M status=noxfer
5. After flash complete, power off safely and eject the sdcard.
Build Source Code
1. Get the bsp source code
 $ git clone https://github.com/BPI-SINOVOIP/BPI-M2M-bsp
2. Build the bsp source code
Advance Development
  • Execute "bluetoothctl"
  • Execute these commands:
 $ sudo su
 # killall wpa_supplicant
 # wpa_passphrase <ssid> <passphrase> > /etc/wpa_supplicant/wpa_supplicant.conf
 # ifconfig wlan0 up
 # iwlist wlan0 scan
 # wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
 # dhclient eth0
There are some other command line ways, please google for them.
StartX
  • apt-get install xorg
  • apt-get install xserver-xorg
  • apt-get install xinit
https://askubuntu.com/questions/518454/what-does-startx-command-do
NAS Application
1. Usb hub + sata to usb
  • HDD is supported
  • SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
