Getting Started with BPI-QCar
Revision as of 09:16, 24 February 2021 by Sinovoip (talk | contribs) (→电机控制)
About BPI-QCar
BPI Q-Car with micro:bit
BPI Q-Car with BPI-Bit
BPI-QCar with BPI-AI board
  • support Micro:bit, PBI:bit(Web:bit) and BPI-AI(WEB:AI) boards
  • support Makecode graphical programming(with micro:bit),support Webduino graphical programming(with BPI:bit),and it also support MicroPython arduino(Micro:bit/BPI:bit)
  • Compact body, strong integrity
  • N20 Miniature reducer
  • Infrared emission, infrared reception, line patrol, speed measurement, atmosphere lamp, I2C interface (support 3.3V and 5V), ultrasonic interface, buzzer, steering gear interface, needle row expansion port, expansion screw hole, etc...Fully functional, strong expansibility
  • Easy to use it.
Motor control
Ambient light control
Ultrasonic sensor control
How to use buzzer
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Buzzer_Demo
IR control
Objective: To master the infrared remote control of Q-CAR
Program effect display: infrared remote control Q-CAR forward and backward and turn
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/IR_Control_Demo
Ultrasonic obstacle avoidance
Program effect display: boot the car forward, ultrasonic detection of the front distance, if the distance is less than 8cm, the car left and right to check the obstacles on both sides, choose the direction of the farther distance to turn, to avoid obstacles.
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Avoidance_Demo
巡线行驶
BPI-QCar with BPI:Bit use MicroPython
BPI-QCare with Micro:Bit use MakeCode
MakeCode programming light Micro:Bit Led
Learning Objectives: Familiarize yourself with basic Makecode applications and display some graphics or text on the Micro:Bit 5*5LED matrix.
Open the Makecode programming environment web side of Micro:Bit:https://makecode.microbit.org/
Create a new project and connect the Makecode blocks with the following routine. For example, the first block "Show Leds" can be found in the "Basic" options column. This block can edit the desired graphics
Right-click building blocks to carry out some operations on the building blocks, such as add notes, delete copy building blocks, as well as access to the corresponding documentation of the building blocks, this for the first time people can provide great help.
The MakeCode programming environment has an emulator with its own simulation of the program to view the effect in real time, usually displayed at the top left
The Makecode programming environment also supports importing project files from outside, such as.hex files that are compiled by Makecode
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-display-graphics.hex
The project file can be imported into Makecode to view and edit after downloading to local, or it can be directly burned to Micro:Bit through USB and run directly
Micro:bit Button control - Base
Learning Objectives: Use the two buttons A/B on Micro:Bit to control the graphics to be output by the LED matrix
On the basis of the section "Using Makecode Programming to Light Micro:Bit", find the building block "On Button A Pressed" in the "Input" option column of Makecode to program
The routine is shown in the figure below. Press the A button to display the English character "A", press the B button to display the English character "B", and press the AB button to display A pattern shaped like A banana
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Using_the_button_1.hex
Micro:bit Button control -advance
Learning objectives: Makecode programming to achieve a count and display button control procedures
Building on the previous section, create a new variable called "A_was_pressed_times" in the "Variables" section of the Makecode. This will generate multiple building blocks for the variable in the "Variables" section
Combine the addition blocks in the "Math" TAB and the Mosaic blocks in the "Variables" TAB. Refer to the following legend
At this point, we realized in the Makecode programming and made A use of the addition counting program, press A button A count to add 1 at the same time the counting value output to the LED matrix, press A button B count to return to 0 and clear the LED matrix display
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Using_the_button_2.hex
The wheel speed
Learning Objectives: Using Makecode programming to read the high and low level signals of the infrared pair tube used for wheel speed measurement on BPI-QCAR and calculate the wheel speed with counting method
The routine is as shown in the figure below. The program is burned into Micro:bit, and the Micro:bit is connected to BPI-QCar. At this time, the left and right wheels of Q-CAR can be read from the USB serial port to the left and right wheel speed
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-Car_velocity_measurement_module.hex
motor control
Learning Objectives: Using Makecode programming to achieve QCar left and right motor forward and reverse control
Routines as shown in the figure below, the program is burned into the Micro: BIT, the Micro: BIT and Q-CAR connection, left and right motor will be turned to 2s at the same time, reverse 2s at the same time, right motor is turned to 2s alone, left motor is turned to 2s alone
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-Car_Motor_control_module.hex
氛围灯控制
学习目标:用MakeCode编程实现对Q-Car上10颗WS2812B彩色氛围灯的控制
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,Q-Car上的10颗WS2812B彩灯将同时以1800ms一周期循环彩虹光效
超声波传感器控制
学习目标:用MakeCode编程实现对Q-Car上HC-SR04超声波扩展模块的控制
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,将HC-SR04超声波扩展模块与Q-Car连接,将5V电源与Q-Car连接
可以从Micro:Bit的USB串口读取到超声波传感器检测到的距离以及Micro:Bit上的温度传感器数据,例程实现了对超声波传感器的温度校准
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-car_Ultrasonic_ranging.hex
蜂鸣器的使用
学习目标:用MakeCode编程编写一段曲子并在Q-Car的蜂鸣器上播放
例程如下图,将程序烧录进Micro:Bit,将Micro:Bit与Q-Car连接,Q-Car上的蜂鸣器将循环两次播放曲子
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-car_Music_Arrangement.hex
